I just have a generic thermostat running on an Rpi with a DHT22 sensor. If I go to the services portion of the HA interface and put in
Domain - climate
Service - set_temperature
{“entity_id”: “climate.Thermostat”, “temperature”: “95”}
then it will change the target temp accordingly. Sadly I could not figure out the API call to make this work. I found THIS post where @jbardi gave a great description of the syntax to call it, but I couldn’t get it to work. Closest I got was using
http://****:8123/api/services/climate.Thermostat/temperature.95?api_password=
This returned a 405: Method Not Allowed, any other deviation I tried just gave me the 404:Not Found unfortunately. Any help is appreciated. Thanks
