Since mid-October, I’ve been using a bunch of devices through Wink. I created a developer account, added a new application, and then fed Hass.io whatever OAUTH settings/URLs it needed. That has worked fine for ~6 weeks.
After my upgrade today, Wink no longer works. Here’s what I’m seeing in the log:
2017-11-30 00:16:15 ERROR (MainThread) [homeassistant.setup] Error during setup of component wink
File "/usr/lib/python3.6/site-packages/homeassistant/setup.py", line 193, in _async_setup_component
component.setup, hass, processed_config)
File "/usr/lib/python3.6/asyncio/futures.py", line 331, in __iter__
yield self # This tells Task to wait for completion.
File "/usr/lib/python3.6/asyncio/tasks.py", line 244, in _wakeup
future.result()
File "/usr/lib/python3.6/asyncio/futures.py", line 244, in result
raise self._exception
File "/usr/lib/python3.6/concurrent/futures/thread.py", line 55, in run
File "/usr/lib/python3.6/site-packages/homeassistant/components/wink/__init__.py", line 320, in setup
pywink.get_subscription_key())
File "/usr/lib/python3.6/site-packages/pywink/api.py", line 565, in get_subscription_key
response_dict = wink_api_fetch()
File "/usr/lib/python3.6/site-packages/pywink/api.py", line 584, in wink_api_fetch
raise WinkAPIException("401 Response from Wink API. Maybe Bearer token is expired?")
pywink.api.WinkAPIException: 401 Response from Wink API. Maybe Bearer token is expired?
I see some other threads about this but they are Home Assistant and not Hass.io, so I’m not really sure how transferrable the info is going to be.
EDIT: As I was finishing this post, I found my answer, but figured I’d still post it just in case others have the same issue after their updates.
Went into /config and deleted the .wink.conf file, then restarted Home Assistant and was presented with the option to configure Wink again. Once I did so everything was working fine. Not sure what caused the issue, but not too complicated a fix.
