API integration issue
I am using
  • Home Assistant OS 11.2
  • Home Assistant Supervisor 2023.11.6
  • Home Assistant Core Update 2023.12.1
    I installed a CO2 captor SCD40 on esp8266, board: d1_mini (framework: version 2.7.4)
When I try to call the api, I get compilation errors.
Sample Code to call the api :
api:
encryption:
key: “#SecretKey
Logs obtained when code related to api is enabled :
INFO ESPHome 2023.11.6
INFO Reading configuration /config/esphome/co2.yaml…
WARNING The selected Arduino framework version is not the recommended one. If there are connectivity or build issues please remove the manual version.
INFO Generating C++ source…
INFO Compiling app…
Processing co2 (board: d1_mini; framework: arduino; platform: platformio/[email protected])
HARDWARE: ESP8266 80MHz, 80KB RAM, 4MB Flash
Dependency Graph
|-- ESP8266WiFi @ 1.0
|-- ESP8266mDNS @ 1.2
|-- noise-c @ 0.1.4
|-- Wire @ 1.0
|-- FastLED @ 3.3.2
Compiling .pioenvs/co2/src/esphome/components/api/api_connection.cpp.o
Compiling .pioenvs/co2/src/esphome/components/api/api_server.cpp.o
Compiling .pioenvs/co2/src/esphome/components/api/list_entities.cpp.o
Compiling .pioenvs/co2/src/esphome/components/api/subscribe_state.cpp.o
In file included from src/esphome/components/api/api_connection.h:6:0,
from src/esphome/components/api/api_connection.cpp:1:
src/esphome/components/api/api_server.h:118:96: error: invalid use of ‘::’
Trigger<std::string, std::string> *client_connected_trigger_ = new Trigger<std::string, std::string>();
src/esphome/components/api/api_server.h:118:96: error: expected ‘;’ at end of member declaration
src/esphome/components/api/api_server.h:118:102: error: expected unqualified-id before ‘>’ token
src/esphome/components/api/api_server.h:119:99: error: invalid use of ‘::’
Trigger<std::string, std::string> *client_disconnected_trigger_ = new Trigger<std::string, std::string>();
src/esphome/components/api/api_server.h:119:99: error: expected ‘;’ at end of member declaration
src/esphome/components/api/api_server.h:119:105: error: expected unqualified-id before ‘>’ token
src/esphome/components/api/api_server.h:118:83: error: template argument 1 is invalid
src/esphome/components/api/api_server.h:119:86: error: template argument 1 is invalid
In file included from src/esphome/components/api/api_server.cpp:1:0:
from src/esphome/components/api/subscribe_state.cpp:2:
from src/esphome/components/api/list_entities.cpp:5:
cc1plus: warning: unrecognized command line option “-Wno-nonnull-compare” [enabled by default]
*** [.pioenvs/co2/src/esphome/components/api/list_entities.cpp.o] Error 1
*** [.pioenvs/co2/src/esphome/components/api/subscribe_state.cpp.o] Error 1
*** [.pioenvs/co2/src/esphome/components/api/api_connection.cpp.o] Error 1
*** [.pioenvs/co2/src/esphome/components/api/api_server.cpp.o] Error 1
========================== [FAILED] Took 3.09 seconds ==========================
Can anyone please guide me where I should look or if the api sample is correct and compatible with used frameworks and versions ?
