Hey Guys,
I havent had any issues up until last night. The only thing that changed was that I updated to the latest. I tried restoring a backup but that was the same issue. Can any help?
Logger: homeassistant.components.websocket_api.http.connection
Source: components/websocket_api/commands.py:238
Integration: Home Assistant WebSocket API (documentation, issues)
First occurred: 12:15:16 PM (3 occurrences)
Last logged: 12:18:33 PM
[140590697487040] {'msg': 'Something went wrong with your request.\nPlease try again later.', 'code': 100001}
File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 238, in handle_call_service
response = await hass.services.async_call(
File "/usr/src/homeassistant/homeassistant/core.py", line 2149, in async_call
response_data = await coro
File "/usr/src/homeassistant/homeassistant/core.py", line 2186, in _execute_service
return await target(service_call)
File "/usr/src/homeassistant/homeassistant/helpers/entity_component.py", line 272, in handle_service
return await service.entity_service_call(
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 882, in entity_service_call
single_response = await _handle_entity_call(
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 952, in _handle_entity_call
result = await task
File "/config/custom_components/ac_infinity/switch.py", line 256, in async_turn_off
await self.entity_description.set_value_fn(
File "/config/custom_components/ac_infinity/ac_infinity.py", line 228, in set_device_port_setting
await self.set_device_port_settings(device_id, port_id, [(setting, value)])
File "/config/custom_components/ac_infinity/ac_infinity.py", line 237, in set_device_port_settings
await self._client.set_device_port_settings(
File "/config/custom_components/ac_infinity/client.py", line 105, in set_device_port_settings
_ = await self.__post(API_URL_ADD_DEV_MODE, payload, headers)
File "/config/custom_components/ac_infinity/client.py", line 119, in __post
raise ACInfinityClientRequestFailed(json)
custom_components.ac_infinity.client.ACInfinityClientRequestFailed: {'msg': 'Something went wrong with your request.\nPlease try again later.', 'code': 100001}
