I have a small problem with the resent update. I did a clean install of HA a few months ago an added all components back in. The Sonoff Pro I’m using works fine but does not show in the ESPHome as a device. Now with update I see that the API Password is deprecated. How can I login to the Sonoff Pro to resolve the issue if it is not in the ESPHome as a device?
Do I need to hookup a usb cable or can I login some how of my network ?
I assume you have flashed to ESPHome? I have Sonoff 4ch pro but with no API password
does it show up on the network? can you see it from the router?
did you set up a fixed ip address?
fall back AP?
yaml?
Yes it has been flashed and running for a few months. I can see it on my network with a static IP. I did setup a fall back AP but don’t remember what it is.
To clarify; do you have the node already set up in ESPHome dashboard? With the original YAML? Is it just not showing as connected? Is it showing up in integrations?
@Dayve67 Indeed if the worst comes to the worse you have a file if you need serial flash. And you have the AP password! I am guessing that you create a new node in ESPHome using this file as your yaml for the new entity. See whether it now connects. Somebody might know whether that will work
