Hey,
I upgraded to 0.74.0, installed the new user support (which works beautifully, btw!), but can’t manage to get the legacy API password support working anymore. I set my stuff up like this:
I also have:
What am I doing wrong?
Hey,
I also have:
Any error log?
in auth section there should be an auth:
For lack of having your whole cofiguration: # Enable the auth component
auth: ? In the documentation about this new feature.
Example configuration.yaml entry
homeassistant:
auth_providers:
- type: homeassistant
Uncomment next line if you want to enable legacy API password support
- type: legacy_api_password
homeassistant:
auth_providers:
auth:
I do have an “auth:” at the end as specified in the docs, but I don’t need any actual parameters in it, right?
As for the logs, sorry, still a newbie at this, where exactly do I find the relevant log for this?
Thanks a lot!
Are you upgrade from previous or new installation?
Is your config worked in previous release?
You didn’t show the full configuration, so I don’t have idea which is your notify.Chrome
What is your mean
You can’t login with leagacy api password auth provider?
You can’t get image from camera_proxy?
Let me make an assumption you are talking about camera_proxy, can this camera display image in HA web app?
Can you see an image, if you directly browse https://your.local.ip:8123/api/camera_proxy/camera.living_room?api_password=MYPASSWORD
And there is a known issue for this usage (not only for 0.74), MYPASSWORD cannot include special characters, such as &, =, etc.
And also there are other users reported that their SSL certification has issue since 0.73.2 security patch, not related with new auth.
You’re the best!
When upgrading to 0.74, I also changed the API password to one that included special characters (although I had an exclamation mark in the previous API password as well), I changed it to one without special characters and it works again
Much appreciated!
