App #4: Boiler Alert
Another example :grinning:
This automation is not final or complete, and probably there is a way to make more generic. My aim is to share examples that maybe can help new members starting with HA+AppDaemon.
Suggestions or recommendations to improve the implementation are welcome!
Notify me if the boiler fires three Floor Heating Failures and one Internal Failure within one hour. Do not notify me more than once per hour.
For this automation, I use the same approach used in App #1: Doorbell notification to keep track of the last notification. I also use timers to create a sliding window effect and correlate failures occurred within the last hour.
Entities
sensor.boiler_alarm
boiler_alert.yaml
boiler_alert:
  module: boiler_alert
  class: BoilerAlert
  sensor: sensor.boiler_alarm
  failures:
    - name: fh_sensor_failure
      amount: 3
    - name: i_sensor_failure
      amount: 1
boiler_alert.py
import appdaemon.plugins.hass.hassapi as hass
from datetime import datetime, timedelta
class BoilerAlert(hass.Hass):
    def initialize(self):
        self.log('initializing ...')
        self.events = {}
        self.last_notification = datetime.now() - timedelta(hours= 2)
        sensor = self.args["sensor"]
        for failure in self.args["failures"]:
            failure_name = failure["name"]
            self.events[failure_name] = 0
            self.log(f'subscribing to <{failure_name}> from <{sensor}> ')
            self.listen_state(self.on_boiler_failure, sensor, new=failure_name)
    def on_boiler_failure(self, entity, attribute, old, new, kwargs):
        currCount = self.events[new]
        self.events[new] = currCount+1
        self.run_in(self.__update_counter, 3.600, event = new)
        notify_now = True
             failure_amount = failure["amount"]
             if self.events[failure_name] < failure_amount :
                 notify_now = False
        # only check the time condition if we have the amount the failures needed.
        if notify_now and self.last_notification > (datetime.now() - timedelta(hours= 1)):
            notify_now = False
        if notify_now:
            self.log('Send Boiler Alert Notification')
        else: # only used for debugging purposes
            self.log('Waiting ...')
    def __update_counter(self, kwargs):
        event = kwargs["event"]
        currCount = self.events[event]
        self.events[event] = currCount-1
Did I use the right approach to keep track of the failures? If you have a better approach, please share it :slightly_smiling_face:
Happy coding!
Humberto
Edit #1 Avoid hardcode entities names in the automation code. Thanks @swiftlyfalling @Burningstone, and @ReneTode for your help on the discord server
Edit #2 Update code based on the feedback received by @ReneTode (see his code below)
Previous post: App #3: Smart Radiator
Next post: App #5: Smart Radiator (Generic)
if you really like it flexible i would get the failure events out of the code.
and name the yaml the same as the code file, that would save others the trouble from renaming.
boiler_alert.yaml (and you got a double entry in your yaml)
boiler_alert:
  class: BoilerAlert
  failures:
    - {"fh_sensor_failure": 3}
    - {"i_sensor_failure": 1}
boiler_alert.py
        self.events = {}
        self.last_notification = datetime.now() - timedelta(hours= 1)
            for failure_name, failure_amount in failure.items():
                self.log(f'subscribing to failure {failure_name} from {sensor} ')
        notify_now = True
                if self.events[failure_name] < failure_amount:
                    notify_now = False
        if self.last_notification < (datetime.now() - timedelta(hours= 1)):
            notify_now = False
        if notify_now:
        self.log('event: ' +event)
keep up the good work
Thanks again for your feedback @ReneTode!
The right operator for this version is > instead of <
if self.last_notification > (datetime.now() - timedelta(hours= 1)):
    notify_now = False
That small change and everything worked perfectly :+1:
I also did other minor changes to your solution to avoid the two nested for. I used a list instead of a dictionary as an alternative to a tuple as they are not supported by YAML. I will update the code of my initial solution based on your feedback and my changes.
@ReneTode :+1::+1:
yup, didnt look at it correctly and copy pasted :wink:
its always about choices.
i mostly use dicts. thats because i know that yaml is 1 big dict anyway.
in this case it was a list with dicts which off course also could be made more readable like:
boiler_alert:
  class: BoilerAlert
  failures:
    - failure: fh_sensor_failure
      failure_amount: 3
    - failure: i_sensor_failure
      failure_amount: 1
it all depends on what you like more and what you find more readable.
@ReneTode once again many thanks for your feedback!
I definitely have to read more about YAML, your last suggestion is indeed more readable (at least for me)
I’m updating my code now :+1:
