Hello/Hallo/Hola ![]()
New Example!
This automation is not final or complete, and probably there is a way to make more generic. My aim is to share examples that maybe can help new members starting with HA+AppDaemon.
Suggestions or recommendations to improve the implementation are welcome!
Predictive maintenance for domotics is as important as for big industries. We always want to system online and avoid breakdowns ![]()
App #7: Boiler Temperature Alert
Notify me if the temperature of my boiler reaches more than three times X °C (e.g., 60) within a time window of an hour.
Entities
sensor.boiler_temperature
app.yaml
boiler_temperature_alert:
module: boiler_temperature_alert
class: BoilerTemperatureAlert
sensor: sensor.boiler_temperature
boiler_temperature_alert.py
import appdaemon.plugins.hass.hassapi as hass
from datetime import datetime, timedelta
class BoilerTemperatureAlert(hass.Hass):
def initialize(self):
self.log('initializing ...')
self.times = []
self.listen_state(self.on_temperature_change, self.args["sensor"])
def on_temperature_change(self, entity, attribute, old, new, kwargs):
if int(new) > 60: # validate temperature condition
if len(self.times) == 2: # check that we already enough temperature values
oneHourAgo = datetime.now() - timedelta(hours= 1)
if all(map(lambda t: t > oneHourAgo, self.times)):
self.log("Sending notification ...")
# your notification
self.times.insert(0, datetime.now())
self.times = self.times[:2] # remove the oldest time
else:
self.log('Temperature > 60 but still not enough values to fire an alert')
Happy coding!
Humberto
Previous post: App #6: Window Alert
Next post: App #8: Detect a particular sequence of events
