Didn’t find an answer to this question and a I think it should be easy.
I have set up zero tier for remote access and it is working with the mobile app with the zero tier URL.
My question is if there is a way to access when at home from app without having zero tier running in my phone. Now I need to keep the ZT app running even when connected to my WiFi.
I think the internal URL field will be grey until you setup the Home network WiFi SSID field.
How did you configure the zerotier URL? Any guide to follow? I’d be interested to see that.
Ok, I see. Wonder what info I will be sharing if I set up my WiFi ID.
About zero tier config it is easy. Lot of guides around. Just get a free zt account, install the zt add-on in HA and use the ZT IP:8123 to login remote. Should you have any specific doubt let me know.
I think all it does is tell the companion app that when connected to that wifi SSID that you are to be assumed “home” and then proceed to use the local URL.
