I see Connected to HA realtime API then the app crashes and closes. This occurs after a removal and re-install.
In my case it’s a bit different.
On the first start of the app I can set my settings and with a tap on the save button the app crashes.
Every time I open the app after that it crashes again.
With my own instance of hass or with the online demo, it’s always the same.
iPhone 6 with iOS 9.3.1
Python 3.4.2
Hass 0.16.1
I got a solution.
The problem occurs if you don’t set a password inside the app. If you set one the app works, even if your HA Instance has no password.
Greets
Jacko
This should have been fixed in builds 21/22, but let me know if it’s still an issue.
Happening to me on version .28
I am still getting this exact error. I enter my settings and hit save. App crashes and crashes everytime I reopen it. I must uninstall and reinstall to try again. I never get past the login screen.
After removing and re-installing the app today (in an effort to get the notification token ID to show up) I now see this crash. It connects to HASS and then shuts down.
I found the reason for the crash. In the search for the notification token ID at some point I added this to the config:
ios:
health_check: true
push_categories:
- name: Generic
identifier: 'GENERIC'
This seems to crash the app.
