App logout on every phone reboot or app upgrade
Hello community, I’m facing an annoying issue on app since I changed my phone (now I have Sansung Galaxy S22U).
Every time I need to reboot my phone or HA app is upgraded by store, or simply I close it, I need to login again. Regarding close the app I solved keeping it always open, but still got login issue after phone reboot or HA app got updated.
Every time I have to fill address, name, password, otp… and that’s very annoying, even because I tried everything to address such issue. Clear cache/data, uninstall/install app, give it all permissions, and so on.
Could someone address me to a root cause? Previous phone (Samsung Galaxy S10+) didn’t suffer from this issue.
Thank you
Lucas
Check that either default_config: or mobile_app: is in your Configuration.yaml
If one of them is, then try following these steps: Troubleshooting | Home Assistant Companion Docs
if that fails get the companion app logs immediately after logging back into the app
Hi, thank you for fast reply, none of these are present in HA configuration.yaml
I checked the documentation there and it just report to add:
mobile_app:
Is it ok? Anything else?
Thank you
Lucas
yup thats fine, it was either or…default_config would be easier to enjoy newly added HA features.
Thank you very much! Now after reboot I don’t have to login again!!! :heart_eyes:
