App Notification That Actually Opens the App When Clicked
Trying to understand the process of getting a notification that will open the HA app on my phone to the correct screen. (Reading here: Actionable Notifications | Home Assistant Companion Docs)
In my case I’m trying to get my door locks to all automatically lock at night, and then report to my phone if there’s a problem (ie Lock is jammed or didn’t lock due to door being open, etc). This is the default action for my “choose” tree. When it executes, I get the notification on my Android (Samsung S21 Plus) but clicking on the notification doesn’t cause it to go to the app. I’ve tried a handful of format changes and nothing has gotten it working. Any insight?
default:
  - service: notify.mobile_app_russ_phones21plus
      message: >-
        SECURITY ALERT<br> {% if is_state('binary_sensor.alarm_side_entry_door',
        'off') and is_state('lock.side_door_lock','locked') and
        is_state('binary_sensor.side_door_lock_access_control_lock_jammed','off')
        %} Side Door is Locked  {% elif
        is_state('binary_sensor.side_door_lock_access_control_lock_jammed','on')
        %} Side Door is JAMMED {% else %} Side Door is Unlocked {% endif %}
      title: SECURITY ALERT
        sticky: true
        action: URI
        title: "Open Security Tab"
        uri: "/lovelace/security"
I have also tried these
default:
      message: >-
        - actions:
            sticky: true
            action: URI
this one doesn’t give me any errors when saving, but doesn’t actually send the message either.
default:
      message: >-
      - actions:
        sticky: true
        action: URI
        uri: /lovelace/security
This post helped me a lot to understand the new actionable notifications:
https://community.home-assistant.io/t/easier-notifications-in-ios-2021-5/306952
For android, here’s an example from my own automations:
        - service: notify.all_mobile
            title: "Security Alert"
            message: "The Garage Door has been open for <b>{{ (15 + ((repeat.index - 1) * 5)) }}</b> minutes."
              image: "{{ states('sensor.snapshot_remote_garage') }}{{ notify_image }}"
              clickAction: "/lovelace/camera_garage"
              ttl: 0
              color: red
              priority: high
              tag: garage_door_open
              channel: Security Alert
              group: Security
              actions:
                - action: "URI"
                  title: "View Camera"
                  uri: "/lovelace/camera_garage"
                - action: "alert_close_garage_door"
                  title: "Close Door"
The URI action launches the HA Companion App on the specified tab (a streamed view of the camera).
Looking at your automations and the documentation you are missing some of the structure - I’m a bit rushed, but the below should work I think:
default:
      message: >-
        sticky: true
        actions:
          - action: "URI"
Thank you - that does appear to work, albeit not quite how i had pictured.
If I expand the alert on my phone then I get a button i can click and it does open the tab in HA.
I was hoping to have the app open by just clicking on the alert message itself. Is this possible?
I’m looking through the link pedolsky posted as well, but I’m not getting that lightbulb moment.
Using a clickAction instead of action: "URI"should give that functionality. There’s one in the example I posted abovee
Legendary! Thank you!
That was the exact bit I was missing. But now I’m excited about the possibilities with the buttons and responses possible.
Now I can figure out how to add a “lock doors” button so if I can lock the doors when the wife forgets.
My example contains:
That “Close Door” button triggers an automation to close the garage door based on the action (as event_data), removes the “door open” notification identified by it’s unique tag and sends a follow up notification with camera image confirming closure:
- id: actiononalert_close_garage_door
  alias: "Action On Alert - Close Garage Door"
  mode: single
    - platform: event
      event_type: mobile_app_notification_action
      event_data:
        action: alert_close_garage_door
  condition: []
    - variables:
        notify_image: "garage_motion_{{ now().strftime('%Y%m%d%H%M%S') }}.jpg"
    - service: cover.close_cover
        entity_id: cover.garage_door
    - service: camera.snapshot
        entity_id: camera.garage
        filename: "{{ states('sensor.snapshot_local_garage') }}{{ notify_image }}"
    - service: local_file.update_file_path
        entity_id: camera.garage_last_motion
        file_path: "{{ states('sensor.snapshot_local_garage') }}{{ notify_image }}"
    - service: input_datetime.set_datetime
        entity_id: input_datetime.last_garage_motion
        time: "{{ (as_timestamp(now()) | timestamp_custom('%H:%M:%S', true)) }}"
        date: "{{ (as_timestamp(now()) | timestamp_custom('%Y-%m-%d', true)) }}"
        message: clear_notification
        title: "Garage Door Closing"
        message: "Closing garage door as requested at {{ (as_timestamp(now()) | timestamp_custom('%H:%M', true)) }}."
          tag: garage_door_closed
          group: Garage
