App on Android stops sending any data - Requires re-install
Hi, I’ve a Google Pixel 6 Pro running Android 13 all fully patched.
I upgraded to 2022.8 of the app yesterday and immediately all sensors from the phone stopped. HA shows all of them as Unavailable. HA is OS v 2022.08.6 (I usually wait a few .0 versions before updating)
I’ve uninstalled the app and removed the phone entry from the Mobile App integration. Reboot both and re-add the mobile app.
This goes well but only with the default sensors active, as soon as I start to enable more sensors the updates stop and won’t restart without full removal of the app and re-install…
Is this a known bug or am I missing something?
I’ve run the app in it’s various versions for over 2 years without any problems.
TIA. Pete
Check the companion app logs for errors after reproducing the issue
Can only find the change log, can you tell me where the app log is located? Thanks
Just above the change log. Settings > Companion App > Show and share logs
