Trying to install the supervised on Debian 10 Machine , all the Dependencies are installed as per github documentation .But getting error that apparmor is missing error , even though apparmor is already installed .
[warn]
[warn] If you want more control over your own system, run
[warn] Home Assistant as a VM or run Home Assistant Core
[warn] via a Docker container.
[warn]
[warn] If you want to abort, hit ctrl+c within 10 seconds...
[warn]
[warn] The following is missing on the host and needs
[warn] to be installed and configured before running this script again
[error] missing: apparmor
Assistant@server01:~$ sudo apparmor_status
apparmor module is loaded.
3 profiles are loaded.
3 profiles are in enforce mode.
docker-default
nvidia_modprobe
nvidia_modprobe//kmod
0 profiles are in complain mode.
0 processes have profiles defined.
0 processes are in enforce mode.
0 processes are in complain mode.
0 processes are unconfined but have a profile defined.
Assistant@server01:~$ sudo apt list --installed | grep apparmor
apparmor-utils/stable,now 2.13.2-10 amd64 [installed]
apparmor/stable,now 2.13.2-10 amd64 [installed]
libapparmor1/stable,now 2.13.2-10 amd64 [installed]
python3-apparmor/stable,now 2.13.2-10 amd64 [installed,automatic]
python3-libapparmor/stable,now 2.13.2-10 amd64 [installed,automatic]
Assistant@server01:~$ sudo apt list --installed | grep docker-ce
docker-ce-cli/buster,now 5:20.10.3~3-0~debian-buster amd64 [installed,automatic]
docker-ce-rootless-extras/buster,now 5:20.10.3~3-0~debian-buster amd64 [installed,automatic]
docker-ce/buster,now 5:20.10.3~3-0~debian-buster amd64 [installed]
Assistant@server01:~$ sudo apt list --installed | grep network-manager
network-manager/stable,now 1.14.6-2+deb10u1 amd64 [installed]
