Hi guys. I was working with the guide from the developer site to create an apparmor.txt file. The provided examlle did not work. It appears the guide is incomplete and leaves you with an inoperable setup when using the default example.
I hacked on it for a while and came up with this minimum addon AppArmor
Additionally there is some weirdness where the level 6 rating is only applied after the Addon is installed, but it works to get that Level 6!
