Hi everyone,
I tried to build an app that turns on the light to a certain brightness based on the state of the day.
I already have an app, which changes an input select to the current state of the day, e.g. Monday between 9:00 and 23:00 the input select would show “Tag Wochentag”.
The app I trying to build does not execute until the end.
The app called montion_light_v2.py looks like this:
import appdaemon.plugins.hass.hassapi as hass
# App to turn on light when motion is detected, then turn off after few delay
# If the computer is on, a trigger of the motion sensor has no effect
# args:
# sensor: motion sensor to use as trigger
# light_entity: light to turn on/off
# delay: time until light turns off again, default 30 seconds
# input_select: name of the input_select which shows time of day
# brightness_level: brightness level in % for different periods of day
# Morgen Wochentag: 30
# Tag Wochentag: 70
# Nacht Wochentag:
# Morgen Wochenende:
# Tag Wochenende:
# Nacht Wochenende:
class MotionLight(hass.Hass):
def initialize(self):
self.handle = None
if "delay" in self.args:
self.delay = self.args["delay"]
else:
self.delay = 30 # default delay
if "sensor" in self.args:
self.listen_state(self.motion, self.args["sensor"])
def motion(self, entity, attribute, old, new, kwargs):
if new == "on":
self.log("Motion detected")
if self.get_state(self.args["light_entity"]) == "on":
self.log("Light is already on, restart timer")
self.cancel_timer(self.handle)
self.handle = self.run_in(self.light_off, self.delay)
else:
self.log("Turn on light and set timer")
self.brightness_map = self.args["brightness_level"]
self.log("error here")
self.log(self.brightness_map)
state_of_day = get_state(self.args["input_select"])
self.log(state_of_day)
self.log("error later")
desired_brightness = self.brightness_map[state_of_day]
self.log(desired_brightness)
self.turn_on(self.args["light_entity"], brightness = desired_brightness)
def light_off(self, kwargs):
self.turn_off(self.args["light_entity"])
The configuration looks like this:
Light Dress Room:
module: motion_light_v2
class: MotionLight
delay: 300
sensor: binary_sensor.aeotec_zw100_multisensor_6_sensor_9
light_entity: light.ankleidezimmer
input_select: input_select.state_of_day
brightness_level:
Tag Wochentag: 70
Nacht Wochentag: 10
Morgen Wochenende: 30
Tag Wochenende: 70
Nacht Wochenende: 10
As soon as the app detects motion, it starts but it does not turn the light on. The log file shows the following:
2018-07-20 17:04:00.013997 INFO State of Day: Changed input select to Tag Wochentag.
2018-07-20 17:04:18.729353 INFO Light Dress Room: Motion detected
2018-07-20 17:04:18.729900 INFO Light Dress Room: Turn on light and set timer
2018-07-20 17:05:00.013558 INFO State of Day: Changed input select to Tag Wochentag.
So it looks like the execution stops at “self.brightness_map = self.args[“brightness_level”]”.
I don’t understand what I did wrong, your help would be highly appreciated.
Thanks in advance and best regards
