Hi all. I’m having some trouble calling deconz configure.
How would a appdaemon call_service look to implement this example
from another thread:
- service: deconz.configure
entity: light.closet
field: "/state"
data: {"bri_inc":-254, "transitiontime":50}
Not like this anyway…
mydata="{\"bri_inc\":-254, \"transitiontime\":50}"
self.call_service("deconz/configure", field='/state' ,entity='light.closet',
data=mydata)
Have a nice day.
You can import the json library and then try like this:
mydata={"bri_inc": -254, "transitiontime": 50}
self.call_service(
"deconz/configure",
field='/state',
data=json.dumps(mydata)
The json.dumps method converts a python dictionary into JSON.
Thanks, but no luck. The error is:
requests.exceptions.HTTPError: 400 Client Error: Bad Request for url: http://192.168.1.3:8123/api/services/deconz/configure
I’m out of ideas. Is the configure portion not exposed in hass rest api?
Hello @Flurken,
This this instead
self.call_service(
"deconz/configure",
field='/state',
**mydata
Regards
Does the service call work when you enter it manually into the services tool of home assistant?
@Burningstone
Yep. Works fine that way. I tried calling it with a rest client. Just getting a 405.
Ok that’s strange. Fortunately I also have Deconz. I’ll test it on my system as well as soon as I’m home.
Can you please show me the command you entered in the Services tool?
I just tested and this works for me:
self.call_service(
"deconz/configure",
field='/state',
entity='light.decke_1_buero',
data=mydata
Please be informed that if light.closet is a group than field needs to be ‘/action’, if it is a single light then the field needs to be ‘/state’. In addition if it is a group it only works if it is a deconz group, if you created the group in home assistant it doesn’t work.
Hi, and thanks your your engagement.
Works fine using your example. I’m an idiot. For some reason I assumed (why?) that the data needed to be text/json and not that you could simply just send a dictionary (as you should).
Thank you again and have a nice weekend.
