Hi everybody,
could somebody please help me to initially set up AppDaemon
to work with my Home Assistant
I ran both hass and appdaemon as separate docker containers.
appdaemon.yaml
log:
logfile: STDOUT
errorfile: STDERR
appdaemon:
threads: 10
plugins:
HASS:
type: hass
ha_url: "http://<url>:8123"
token: "<token>
hadashboard:
dash_url: "http://<url>:<port>"
Multiple AppDaemon scripts are installed in home assistant via HACS
. They are placed in config/appdaemon/apps/<each_script>/
. Then there is config/appdaemon/apps/apps.yaml
, which currently contains
people_at_home:
module: people_tracker
class: PeopleTracker
guest_entity_id: input_boolean.guests # took this from the example config; this entity does not actually exist
entities:
- entity.1
- entity.2
- entity.3
The appdaemon container path contains
docker-compose.yaml
apps/
compiled/
css/default/hello_application.css
html/default/
hello_body.html
hello_head.html
javascript/
application.js
default/hello_init.js
dashboards/Hello.dash
The apps.yaml
file looks exactly the same as the config/appdaemon/apps/apps.yaml
in the Home Assistant docker file. This is the output when I run docker-compose up
Starting appdaemon ... done
Attaching to appdaemon
appdaemon | 2020-05-03 09:14:27.724792 INFO AppDaemon Version 3.0.5 starting
appdaemon | 2020-05-03 09:14:27.725102 INFO Configuration read from: /conf/appdaemon.yaml
appdaemon | 2020-05-03 09:14:27.726539 INFO AppDaemon: Starting Apps
appdaemon | 2020-05-03 09:14:27.729741 INFO AppDaemon: Loading Plugin HASS using classHassPlugin from module hassplugin
appdaemon | 2020-05-03 09:14:27.862385 INFO AppDaemon: HASS: HASS Plugin Initializing
appdaemon | 2020-05-03 09:14:27.862780 INFO AppDaemon: HASS: HASS Plugin initialization complete
appdaemon | 2020-05-03 09:14:27.863024 INFO Starting Dashboards
appdaemon | 2020-05-03 09:14:27.868647 INFO API is disabled
appdaemon | 2020-05-03 09:14:27.920905 INFO AppDaemon: HASS: Connected to Home Assistant 0.109.1
appdaemon | 2020-05-03 09:14:28.123383 INFO AppDaemon: Got initial state from namespace default
appdaemon | 2020-05-03 09:14:29.991703 INFO AppDaemon: Reading config
appdaemon | 2020-05-03 09:14:29.994291 INFO AppDaemon: /conf/apps/apps.yaml added or modified
appdaemon | 2020-05-03 09:14:29.994457 INFO AppDaemon: /conf/apps/apps.yaml added or modified
appdaemon | 2020-05-03 09:14:29.994656 INFO AppDaemon: App 'people_at_home' added
appdaemon | 2020-05-03 09:14:29.994824 INFO AppDaemon: Adding /conf/apps to module import path
appdaemon | 2020-05-03 09:14:29.995047 INFO AppDaemon: Initializing app people_at_homeusing class PeopleTracker from module people_tracker
appdaemon | 2020-05-03 09:14:29.995148 WARNING AppDaemon: Unable to find module modulepeople_tracker - people_at_home is not initialized
appdaemon | 2020-05-03 09:14:29.995778 INFO AppDaemon: App initialization complete
I am not sure how to initialize anything; also, the hello
dashboard (which will only display a box containing “hello world”) is the only thing displayed under http://<ip>:<appdaemon-port>
; there is not a single entity within Home Assistant
indicating that AppDaemon
is connected, or anything related to appdaemon at all.
What am I doing wrong? Thank you for your help
