AppDaemon Error: Disconnected from Home Assistant, retrying in 5 seconds
I am trying to setup hadashboard using docker. I get this error:
WARNING AppDaemon: HASS: Disconnected from Home Assistant, retrying in 5 seconds
Here is the docker command (:
docker run --rm -it -p 5050:5050 \
  -e HA_URL="http://ha.warllo.org" \
  -e HA_KEY="xxxxxxxx" \
  -e DASH_URL="http://$HOSTNAME:5050" \
  acockburn/appdaemon:latest
I am able to connect via a browser to my homeassistant which is also running in docker on the same host.
Here is the command used to start ha:
docker run -d --name="home-assistant" --restart unless-stopped -v /my-docker/homeassistant:/config -v /etc/localtime:/etc/localtime:ro --net=host homeassistant/home-assistant
I am able to browse to my ha instance using
https://ha.warllo.org
http://192.168.2.4:8123
trying to use https://192.168.2.4:8123 generates a ssl error
I have setup letscrypt by using an apache reverse proxy here is the config for that:
<VirtualHost *:80>
  ServerName ha.warllo.org
  ProxyPreserveHost On
  ProxyRequests off
  ProxyPass /api/websocket ws://192.168.2.4:8123/api/websocket
  ProxyPassReverse /api/websocket ws://192.168.2.4:8123/api/websocket
  ProxyPass / http://192.168.2.4:8123/
  ProxyPassReverse / http://192.168.2.4:8123/
  RewriteEngine on
  RewriteCond %{HTTP:Upgrade} =websocket [NC]
  RewriteRule /(.*)  ws://192.168.2.4:8123/$1 [P,L]
  RewriteCond %{HTTP:Upgrade} !=websocket [NC]
  RewriteRule /(.*)  http://192.168.2.4:8123/$1 [P,L]
</VirtualHost>
Here is the ssl reverse proxy config:
<VirtualHost *:443>
  ProxyRequests off
  RewriteEngine on
SSLCertificateFile /etc/letsencrypt/live/ha.warllo.org/fullchain.pem
SSLCertificateKeyFile /etc/letsencrypt/live/ha.warllo.org/privkey.pem
Include /etc/letsencrypt/options-ssl-apache.conf
</VirtualHost>
Lastly here is the HA Config:
homeassistant:
  # Name of the location where Home Assistant is running
  # Location required to calculate the time the sun rises and sets
  latitude: 0
  longitude: 0
  # Impacts weather/sunrise data (altitude above sea level in meters)
  elevation: 0
  # metric for Metric, imperial for Imperial
  unit_system: metric
  # Pick yours from here: http://en.wikipedia.org/wiki/List_of_tz_database_time_zones
  time_zone: UTC
  # Customization file
  customize: !include customize.yaml
# Show links to resources in log and frontend
introduction:
# Enables the frontend
frontend:
# Enables configuration UI
config:
http:
  # Secrets are defined in the file secrets.yaml
  # api_password: !secret http_password
  # Uncomment this if you are using SSL/TLS, running in Docker container, etc.
  base_url: ha.warllo.org
  api_password: xxxxxxx
# Checks for available updates
# Note: This component will send some information about your system to
# the developers to assist with development of Home Assistant.
# For more information, please see:
# https://home-assistant.io/blog/2016/10/25/explaining-the-updater/
updater:
  # Optional, allows Home Assistant developers to focus on popular components.
  # include_used_components: true
# Discover some devices automatically
discovery:
# Allows you to issue voice commands from the frontend in enabled browsers
conversation:
# Enables support for tracking state changes over time
history:
# View all events in a logbook
logbook:
# Enables a map showing the location of tracked devices
map:
# Track the sun
sun:
# Enables api_key
api:
# Weather prediction
  - platform: yr
# Text to speech
tts:
  - platform: google
# Cloud
cloud:
group: !include groups.yaml
script: !include scripts.yaml
Any help or suggestions would be greatly appreciated!
did you follow the docs?
in paricular this part:
At this point forward, you can edit configurations on your conf folder and Appdaemon will load them see the AppDaemon Installation page for full instrctions on AppDaemon configuration. Have fun!
and the link in it?
so did you setup appdaemon.yaml?
and if so how does it look?
All resolved and working. For some reason running the docker commands as specified did not work.
I had to run the docker command as follows:
sudo docker run -d \
--name=appdaemon \
--restart on-failure \
-p 5050:5050 \
-v /my-docker/appdaemon:/conf \
-v /my-docker/appdaemon:/certs \
I then created my appdaemon.yaml and everything worked great.
in your first command the link to the config wasnt there.
so probably the original command would have worked if it was complete.
You will probably find it more reliable to use the unencrypted local connection to HA, rather than encrypt the connection and go through your router to the internet and back.
And unrelated to AD, you should disable unencrypted remote access -
