Hi all, trying to get AppDaemon running so I can move on with HADashboard setup/config but I’m running into issues.
Trying to start/test with:
appdaemon -c /home/homeassistant/.homeassistant/conf
2018-11-07 02:39:30.919667 INFO AppDaemon Version 3.0.2 starting
2018-11-07 02:39:30.919974 INFO Configuration read from: /home/homeassistant/.homeassistant/conf/appdaemon.yaml
2018-11-07 02:39:30.921429 WARNING config_file: /home/homeassistant/.homeassistant/conf/appdaemon.yaml is owned by root but appdaemon is running as aj
2018-11-07 02:39:30.922291 WARNING ------------------------------------------------------------
2018-11-07 02:39:30.922405 WARNING Unexpected error during run()
2018-11-07 02:39:30.922499 WARNING ------------------------------------------------------------
2018-11-07 02:39:30.923938 WARNING Traceback (most recent call last):
File "/usr/local/lib/python3.6/dist-packages/appdaemon/admain.py", line 76, in run
self.AD = ad.AppDaemon(self.logger, self.error, self.diag, loop, **appdaemon)
File "/usr/local/lib/python3.6/dist-packages/appdaemon/appdaemon.py", line 108, in __init__
self.plugin_params = kwargs["plugins"]
KeyError: 'plugins'
2018-11-07 02:39:30.924088 WARNING ------------------------------------------------------------
2018-11-07 02:39:30.924214 INFO AppDeamon Exited
Here is my initial appdaemon.yaml:
HASS:
ha_url: http://192.168.1.101:8123
ha_key: <my long life token>
appdaemon:
logfile: STDOUT
errorfile: STDERR
threads: 10
HADashboard:
dash_url: http://192.168.1.101:5050
Any thoughts? Been trying for awhile now to get Appdaemon working with no luck. All of this is being done on an Ubuntu 18.04.1 LTS server machine. Thanks much in advance
