I’m really happy to start using Appdaemon for automation. Now I’m starting to have a couple of apps running and and would like to separate the logs from groups of apps to simplify for myself.
I started with adding user defined log named avfuktare_log
in appdaemon.yaml
(I removed the beginning of the file):
logs:
error_log:
filename: /config/appdaemon/logs/error.log
main_log:
filename: /config/appdaemon/logs/appdaemon.log
access_log:
filename: /config/appdaemon/logs/access.log
diag_log:
filename: /config/appdaemon/logs/diag.log
avfuktare_log:
filename: /config/appdaemon/logs/avfuktare.log
After restart of Appdaemon in HA I get cyclic restarts of Appdaemon and the log shows a couple of things:
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
cont-init: info: running /etc/cont-init.d/00-banner.sh
Add-on: AppDaemon
Python Apps and Dashboard using AppDaemon 4.x for Home Assistant
Add-on version: 0.9.3
You are running the latest version of this add-on.
System: Home Assistant OS 9.3 (aarch64 / odroid-n2)
Home Assistant Core: 2022.10.5
Home Assistant Supervisor: 2022.10.0
Please, share the above information when looking for help
or support in, e.g., GitHub, forums or the Discord chat.
cont-init: info: /etc/cont-init.d/00-banner.sh exited 0
cont-init: info: running /etc/cont-init.d/01-log-level.sh
cont-init: info: /etc/cont-init.d/01-log-level.sh exited 0
cont-init: info: running /etc/cont-init.d/appdaemon.sh
Looking in links: https://wheels.home-assistant.io/musllinux/
Collecting mysql.connector
Downloading mysql-connector-2.2.9.tar.gz (11.9 MB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 11.9/11.9 MB 25.8 MB/s eta 0:00:00
Preparing metadata (setup.py): started
Preparing metadata (setup.py): finished with status 'done'
Building wheels for collected packages: mysql.connector
Building wheel for mysql.connector (setup.py): started
Building wheel for mysql.connector (setup.py): finished with status 'done'
Created wheel for mysql.connector: filename=mysql_connector-2.2.9-cp310-cp310-linux_aarch64.whl size=247968 sha256=f9e44e619065ee4aa93bf3a3f7826d197e1051b5c7660ff00b74d381b3147b8e
Stored in directory: /tmp/pip-ephem-wheel-cache-c2p74mp0/wheels/76/48/9b/da67ff1a18fe8e9d428f9b1a177716d4a7d363d2bbe83bf6cf
Successfully built mysql.connector
Installing collected packages: mysql.connector
Successfully installed mysql.connector-2.2.9
WARNING: Running pip as the 'root' user can result in broken permissions and conflicting behaviour with the system package manager. It is recommended to use a virtual environment instead: https://pip.pypa.io/warnings/venv
cont-init: info: /etc/cont-init.d/appdaemon.sh exited 0
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
services-up: info: copying legacy longrun appdaemon (no readiness notification)
s6-rc: info: service legacy-services successfully started
[09:57:13] INFO: Starting AppDaemon...
File "/usr/bin/appdaemon", line 8, in <module>
sys.exit(main())
File "/usr/lib/python3.10/site-packages/appdaemon/__main__.py", line 443, in main
admain.main()
File "/usr/lib/python3.10/site-packages/appdaemon/__main__.py", line 387, in main
self.logging = logging.Logging(logs, args.debug)
File "/usr/lib/python3.10/site-packages/appdaemon/logging.py", line 274, in __init__
logger = logging.getLogger(args["name"])
KeyError: 'name'
[09:57:18] WARNING: AppDaemon crashed, halting add-on
s6-rc: info: service legacy-services: stopping
There is obviously an error with the name of the logger. I have done what I thought should done according to the logging documentation for Appdaemon.
I also see that mysql.connector
is downloaded every time Appdaemon is restarted. Is this normal?
Main problem is the user defined logging. What is I doing wrong?
Edit: If I remove the last two rows in appdaemon.yaml there is no crash any longer so I’m pretty sure something is wrong with those rows.
Edit 2: I realized that it was me who added the need for mysql.connector in a test app. I still have the crash of Appdaemon due to adding a user defined log file.
