Appdaemon listen_state() numeric value
Hi appdaemon specialists,
last week I spend quite some time to convert some of my YAML automations into appdaemon, so far so good, but I couldn’t find a decent solution to convert the below code. Plan is to find out if the power measured by the “sensor.nodeid_52_power” is between 2 and 420 Watt.
Did look at the “listen_state()” but could not find how to activate the callback on a value between defined limits. I’m afraid it doesn’t exist…
But how to implement this functionality in AD?
Thanks for reading
    scan_interval: 5
    sensors:
      dehumidifyer_off_cycle:
        delay_on:
          minutes: 5
        value_template: >
          {% if states('sensor.nodeid_52_power') | float < 420 and
                states('sensor.nodeid_52_power') | float > 2     %}
          true
          {% else %}
          false
          {%endif%}
Just test it in your callback. Something like:
if float(new) < 420 and float(new) > 2:
    do sonething...
Or in Python, you can simplify it as:
if 2 < float(new) < 420:
     do something...
No, that would be too easy :rofl: must have been one of this late night non-sense coming out of my mouth.
Thanks for showing me the proper direction !
I implemented as below, activate a callback when the power did change and set a binary_sensor according the actual power.
With the binary_sensors I have the possibility to use the duration=xxx.
Its already working for some time exactly as intended…
class kelder(hass.Hass):
    def initialize(self):
        self.set_state("binary_sensor.power_dh_done", state = False)        # 400 Watt
        self.set_state("binary_sensor.power_dh_operating", state = False)   # 600 Watt
        self.set_state("binary_sensor.power_dh_waterfull", state = False)   # 2.5 Watt
        self.set_state("binary_sensor.power_dh_250", state = False)         # >250 Watt
        self.set_state("binary_sensor.dehumidifyer_water_full", state = False)
        # init logger
        self.testlogger.info("- Dehumidifyer Kelder() init")
        self.listen_state(self.nodeid_52_power_changed, "sensor.nodeid_52_power", attribute = "state")
        self.listen_state(self.dehumidifyer_done,       "binary_sensor.power_dh_done", attribute="state", new="on", duration=600 )
        self.listen_state(self.dehumidifyer_waterfull,  "binary_sensor.power_dh_waterfull", attribute="state", new="on", duration=180 )
        # forced switch off when dehumidifyer operating >= 1 hour
        self.listen_state(self.dehumidifyer_forced_off,  "binary_sensor.power_dh_operating", attribute="state", new="on", duration=3600 )
        # clear waterfull flag when operating at power >250Watt
        self.listen_state(self.dehumidifyer_clear_waterfull,  "binary_sensor.power_dh_250", attribute="state", new="on", duration=180 )
    # update the power binary sensors
    def nodeid_52_power_changed(self, entity, attribute, old, new, kwargs)  :
        power = float(self.get_state("sensor.nodeid_52_power") )
        if 0.5 <= power < 5 :
            self.set_state("binary_sensor.power_dh_waterfull", state = "on")
        else :
            self.set_state("binary_sensor.power_dh_waterfull", state = "off")
        if 5 <= power < 420 :
            self.set_state("binary_sensor.power_dh_done", state = "on")
        else :
            self.set_state("binary_sensor.power_dh_done", state = "off")
        if power > 0 :
            self.set_state("binary_sensor.power_dh_operating", state = "on")
        else :
            self.set_state("binary_sensor.power_dh_operating", state = "off")
        # normal operating, needed to clear waterfull flag
        if power > 250 :
            self.set_state("binary_sensor.power_dh_250", state = "on")
        else :
            self.set_state("binary_sensor.power_dh_250", state = "off")
