I’m new to AppDaemon, learning by reading the documentation and various tutorials. I’m trying to create an AppDaemon app that listens for events on a single entity, but I seem to be getting events for every entity. I’m sure it’ll be a beginners mistake, but I can’t spot what it is. Can anyone help? App and logs below.
I’m using AppDaemon v4.2.2 and HA 2022.11.4
The AppDaemon manual uses a syntax like this
hass.listen_state(hass_callback, "sensor.outsidesensor_temperature")
Reading the AppDaemon API documentation I have gotten this working, but I’m curious why I have to use this format rather than the above format that most others seem to use.
self.get_entity("sensor.outsidesensor_temperature").listen_state(self.print_entity)
I also noticed this warning in the logs WARNING AppDaemon: Unknown Plugin Configuration in get_plugin_api()
- any suggestions there? I’ve included my appdaemon.yaml as well below.
Application
import hassapi as hass
class OutsideTemperatureSensorChange(hass.Hass):
def initialize(self):
self.adbase = self.get_ad_api()
self.hass = self.get_plugin_api("hass")
self.adbase.log("Initialising class OutsideTemperatureSensorChange")
self.listen_state(self.print_entity,entity='sensor.outsidesensor_temperature')
def print_entity(self, entity, attribute, old, new, kwargs):
try:
self.log(f'Entity state change for {entity}')
except Exception as e:
print("An exception occurred")
print(e)
Logs
2023-01-11 19:24:18.994253 INFO AppDaemon: Initializing app outsidesensor using class OutsideTemperatureSensorChange from module test-outside-temp-sensor-change
2023-01-11 19:24:18.998402 WARNING AppDaemon: Unknown Plugin Configuration in get_plugin_api()
2023-01-11 19:24:19.000666 INFO outsidesensor: Initialising class OutsideTemperatureSensorChange
2023-01-11 19:24:33.844714 INFO outsidesensor: Entity state change for sensor.openweathermap_pressure
2023-01-11 19:24:33.860593 INFO outsidesensor: Entity state change for sensor.openweathermap_rain
2023-01-11 19:24:33.868016 INFO outsidesensor: Entity state change for sensor.openweathermap_uv_index
2023-01-11 19:24:33.875297 INFO outsidesensor: Entity state change for sensor.openweathermap_forecast_precipitation
2023-01-11 19:24:48.456860 INFO outsidesensor: Entity state change for sensor.lounge_temperature
2023-01-11 19:24:57.642086 INFO outsidesensor: Entity state change for sensor.fridgesensor_temperature
2023-01-11 19:24:57.676640 INFO outsidesensor: Entity state change for sensor.fridgesensor_battery
2023-01-11 19:24:57.701121 INFO outsidesensor: Entity state change for sensor.fridgesensor_humidity
2023-01-11 19:24:57.708786 INFO outsidesensor: Entity state change for sensor.loungesensor_humidity
2023-01-11 19:24:57.716009 INFO outsidesensor: Entity state change for sensor.loungesensor_temperature
2023-01-11 19:24:57.723185 INFO outsidesensor: Entity state change for sensor.loungesensor_battery
2023-01-11 19:24:57.730369 INFO outsidesensor: Entity state change for sensor.outsidesensor2_temperature
2023-01-11 19:24:57.737644 INFO outsidesensor: Entity state change for sensor.outsidesensor2_signal_strength
2023-01-11 19:25:57.798467 INFO outsidesensor: Entity state change for sensor.kitchensensor_battery
2023-01-11 19:26:48.959634 INFO outsidesensor: Entity state change for sensor.lounge_temperature
2023-01-11 19:26:58.062386 INFO outsidesensor: Entity state change for sensor.officesensor_battery_percentage
2023-01-11 19:26:58.101783 INFO outsidesensor: Entity state change for sensor.officesensor_signal_strength
2023-01-11 19:26:58.134126 INFO outsidesensor: Entity state change for sensor.officesensor_humidity
2023-01-11 19:26:58.156423 INFO outsidesensor: Entity state change for sensor.loungesensor_humidity
2023-01-11 19:26:58.175689 INFO outsidesensor: Entity state change for sensor.loungesensor_temperature
2023-01-11 19:26:58.188429 INFO outsidesensor: Entity state change for sensor.loungesensor_signal_strength
2023-01-11 19:26:58.198540 INFO outsidesensor: Entity state change for sensor.outsidesensor2_temperature
2023-01-11 19:26:58.208541 INFO outsidesensor: Entity state change for sensor.outsidesensor2_signal_strength
Config
logs:
main_log:
filename: /home/appdaemon/.appdaemon/log/appdaemon.log
access_log:
filename: /home/appdaemon/.appdaemon/log/access.log
error_log:
filename: /home/appdaemon/.appdaemon/log/error.log
diag_log:
filename: /home/appdaemon/.appdaemon/log/diag.log
log_generations: 5
log_size: 1024
format: "{asctime} {levelname:<8} {appname:<10}: {message}"
appdaemon:
time_zone: Pacific/Auckland
latitude: -40.00000
longitude: 111.1111
elevation: 155
plugins:
HASS:
type: hass
ha_url: http://192.168.1.16:8123
token: (removed)
http:
url: http://192.168.1.16:5050
admin:
