LudoJ
December 30, 2021, 1:42pm
1
I want to make a simple class that catches MQTT change. Here is what I do. But the event is never triggered.
I publish MQTT data manually with MQTT explorer (on windows)
What am I doing wrong ?
class myClass(hass.Hass, mqtt.Mqtt):
def initialize(self):
self.listen_event(self.mqtt_message_received_event, "MQTT_MESSAGE" )
def mqtt_message_received_event(self,eventname,data,kwargs):
self.log("---------------------")
self.log(data[0])
tjntomas
(Tomas Jansson)
December 30, 2021, 3:05pm
2
Please post your appdemon.yaml
file.
Depending on your config, you might need to change the self.listen_event
to
self.listen_event(self.mqtt_message_received_event, "MQTT_MESSAGE", namespace="mqtt")
LudoJ
December 30, 2021, 3:06pm
3
secrets: /config/secrets.yaml
appdaemon:
latitude: ---
longitude: ---
elevation: 2
time_zone: Europe/Amsterdam
plugins:
HASS:
type: hass
http:
url: http://127.0.0.1:5050
admin:
api:
hadashboard:
logs:
error_log:
filename: /config/appdaemon/logs/error.log
main_log:
filename: /config/appdaemon/logs/appdaemon.log
access_log:
filename: /config/appdaemon/logs/access.log
diag_log:
filename: /config/appdaemon/logs/diag.log
tjntomas
(Tomas Jansson)
December 30, 2021, 3:09pm
4
you are missing the MQTT config. Change the plugins section to: (Adjust for your MQTT ip and port)
plugins:
HASS:
type: hass
MQTT:
type: mqtt
namespace: mqtt
client_host: 192.168.1.45
client_port: 1883
