Appdaemon not start
Hi all,
I’m trying to write appdaemon app in hassio but I don’t understand why it not start. It not write any log in /config/logs/appdaemon and not write any file as implemented in the hello.py code. I posted in the following all the file I manipulated asking you help to solve it. (Moreover I use duckdns service to reach hassio from remote, but I don’t know if I had to add it on the appdaemon.yaml file)
/config/appdaemon.yaml:
secrets: # /config/secrets.yaml
log:
  accessfile: /config/logs/appdaemon/access.log
  errorfile: /config/logs/appdaemon/error.log
  logfile: /config/logs/appdaemon/appdaemon.log
  log_generations: 3
  log_size: 1000000
appdaemon:
  app_dir: /config/appdaemon/apps
  plugins:
    HASS:
      type: hass
http:
  http://192.168.1.10:5050
admin:
api:
hadashboard:
  dash_url: http://192.168.1.10:5050
  dash_dir: /config/appdaemon/dashboards
/config/appdaemon/apps/apps.yaml:
hello_world:
  module: hello
  class: HelloWorld
/config/appdaemon/apps/hello.py
import appdaemon.plugins.hass.hassapi as hass
class HelloWorld(hass.Hass):
  def initialize(self):
     f = open("/config/testAD.txt","a")
     f.write("TEST \n")
     f.close()
     self.log("Hello from AppDaemon")
     self.log("You are now ready to run Apps!")
thank you very much
Best regards
So you dont see your testAD.txt file created somewhere?
I have a similiar problem. AD is starting, I can switch an actor as wanted but I dont get any log file message. self.log() ends in nowhere…?
