Hello everyone,
I’m struggling for a few hours with appdaemon on docker / RPI3
Docker is installed and is running ok.
1/ I git cloned the repo https://github.com/home-assistant/appdaemon
on my RPI and changed the dockerfile with a
FROM resin/raspberrypi3-python:3.6.2
Original => https://github.com/home-assistant/appdaemon/blob/dev/Dockerfile
2/ Build the appdaemon image => OK
3/ Ran the following docker command :
`docker run --name=appdaemon -v /home/pi/appdaemon/conf:/conf -p 5050:5050 -e HA_URL=“http://192.168.1.105:8123” -e DASH_URL=“http://:5050$HOSTNAME” 76d1dca80fda``
and got the error :
`2017-08-28 20:58:10.712577 INFO AppDaemon Version 2.1.8 starting
2017-08-28 20:58:10.713105 INFO Configuration read from: /conf/appdaemon.yaml
2017-08-28 20:58:10.880104 INFO Starting Apps
2017-08-28 20:58:11.078243 INFO Got initial state
2017-08-28 20:58:11.079872 INFO Loading Module: /conf/apps/hello.py
2017-08-28 20:58:11.082100 INFO Loading Object hello_world using class HelloWorld from module hello
2017-08-28 20:58:11.356665 INFO hello_world: Hello from AppDaemon
2017-08-28 20:58:11.360537 INFO hello_world: You are now ready to run Apps!
2017-08-28 20:58:11.361014 INFO App initialization complete
2017-08-28 20:58:11.361945 INFO Starting dashboard
2017-08-28 20:58:11.372097 WARNING ------------------------------------------------------------
2017-08-28 20:58:11.372569 WARNING Unexpected error in dashboard thread
2017-08-28 20:58:11.372993 WARNING ------------------------------------------------------------
2017-08-28 20:58:11.376694 WARNING Traceback (most recent call last):
File “/usr/local/lib/python3.6/site-packages/aiohttp/web_urldispatcher.py”, line 401, in init
raise ValueError(‘Not a directory’)
ValueError: Not a directory
File “/usr/src/app/appdaemon/rundash.py”, line 319, in run_dash
setup_routes(conf.dashboard_obj)
File “/usr/src/app/appdaemon/rundash.py”, line 288, in setup_routes
app.router.add_static(’/compiled_javascript’, dashboard.compiled_javascript_dir)
File “/usr/local/lib/python3.6/site-packages/aiohttp/web_urldispatcher.py”, line 845, in add_static
follow_symlinks=follow_symlinks)
File “/usr/local/lib/python3.6/site-packages/aiohttp/web_urldispatcher.py”, line 404, in init
“No directory exists at ‘{}’”.format(directory)) from error
ValueError: No directory exists at ‘/conf/compiled/javascript’
2017-08-28 20:58:11.377177 WARNING ------------------------------------------------------------
2017-08-28 20:58:11.377612 INFO API is disabled
2017-08-28 20:58:11.406037 INFO Connected to Home Assistant 0.51.2``
Any help would be appreciated I don’t know why does this error pop up and how to solve it.
I read it’s maybe because of a perms issue but I logged in the container as root, tried to start appdaemon -c ./conf and same error.
Thank you very much.
