Hi all,
I need to run a subprocess “mount” command from an appdaemon script, but I get error code 255 (Permission Denied).
Output from subprocess run:
CompletedProcess(args=['mount -t nfs4 192.168.68.6:/volume1/NetBackup /mnt'], returncode=255, stdout='', stderr='mount: mounting 192.168.68.6:/volume1/NetBackup on /mnt failed: Permission denied\n')
The same command if executed from the shell of Home Assistant OS works correctly.
How can I do?
Thank you!
