I upgrade to AppDaemon 4.2.1 from some old 4.x.x version and not starting .
it stuck in the Starting Dashboards step and can’t find reason ,
probably my previous configuration break up with 4.2.1
but can’t see where:
log:
2022-10-01 00:58:04.341404 INFO AppDaemon: AppDaemon Version 4.2.1 starting
2022-10-01 00:58:04.342151 INFO AppDaemon: Python version is 3.9.9
2022-10-01 00:58:04.345726 INFO AppDaemon: Configuration read from: /conf/appdaemon.yaml
2022-10-01 00:58:04.346662 INFO AppDaemon: Added log: AppDaemon
2022-10-01 00:58:04.357099 INFO AppDaemon: Added log: Error
2022-10-01 00:58:04.360495 INFO AppDaemon: Added log: Access
2022-10-01 00:58:04.362628 INFO AppDaemon: Added log: Diag
2022-10-01 00:58:04.768899 INFO AppDaemon: Loading Plugin HASS using class HassPlugin from module hassplugin
2022-10-01 00:58:05.248722 INFO HASS: HASS Plugin Initializing
2022-10-01 00:58:05.253969 INFO HASS: HASS Plugin initialization complete
2022-10-01 00:58:05.259378 INFO AppDaemon: Loading Plugin MQTT using class MqttPlugin from module mqttplugin
2022-10-01 00:58:05.410235 INFO MQTT: MQTT Plugin Initializing
2022-10-01 00:58:05.410948 INFO MQTT: Using 'mqtt-client/status' as Will Topic
2022-10-01 00:58:05.420383 INFO MQTT: Using 'mqtt-client/status' as Birth Topic
2022-10-01 00:58:05.422328 INFO MQTT: Using appdaemon_mqtt_client as Client ID
2022-10-01 00:58:05.432091 WARNING AppDaemon: error loading plugin: MQTT - ignoring
2022-10-01 00:58:05.434295 WARNING AppDaemon: ------------------------------------------------------------
2022-10-01 00:58:05.452603 WARNING AppDaemon: Traceback (most recent call last):
File "/usr/local/lib/python3.9/site-packages/appdaemon/plugin_management.py", line 112, in __init__
raise ValueError("Duplicate namespace: {}".format(namespace))
ValueError: Duplicate namespace: default
2022-10-01 00:58:05.455948 WARNING AppDaemon: ------------------------------------------------------------
2022-10-01 00:58:05.504197 INFO AppDaemon: Initializing HTTP
2022-10-01 00:58:05.512047 INFO AppDaemon: Using 'ws' for event stream
2022-10-01 00:58:05.558215 INFO AppDaemon: Starting API
2022-10-01 00:58:05.612894 INFO AppDaemon: Starting Admin Interface
2022-10-01 00:58:05.622563 INFO AppDaemon: Starting Dashboards
compose file:
appdaemon:
container_name: appdaemon
image: acockburn/appdaemon:latest
ports:
- 5050:5050
volumes:
- /etc/localtime:/etc/localtime:ro
- ${PWD}/appdaemon4/config:/conf
depends_on:
- homeassistant
restart: always
conf/appdaemon.yaml:
secrets: /conf/secrets.yaml
logs:
main_log:
filename: /conf/logs/appdaemon.log
error_log:
filename: /conf/logs/error.log
access_log:
filename: /conf/logs/access.log
appdaemon:
time_zone: !secret timezone
latitude: !secret latitude
longitude: !secret longitude
elevation: !secret elevation
missing_app_warnings: 1
production_mode: False
app_dir: /conf/apps
plugins:
HASS:
type: hass
# namespace: appdaemon-hass
#namespace: default
token: !secret appdaemon_token
ha_url: !secret ha_internal
MQTT:
type: mqtt
namespace: default
client_host: !secret mqtt_broker
http:
url: http://192.168.1.112:5050
api:
hadashboard:
admin:
title: AppDaemon
stats_update: realtime
