Appdaemon: reload app when changing other file?
I have an appdaemon app that uses another file (database_handler.py) for handling a sqlite3-database.
Unfortunately appdaemon doesn’t reload my app when I change the database handler and I have to manually change something in the app.py or app.yaml to force a reload.
Is there any way to tell appdaemon to reload an app if my handler changes?
I tried
dependencies:
  - database_handler
but that didn’t work.
Thanks for your help!
Yes, you can reload an app from another app. Check the docs here for the services available. I think app/reload is the one you are looking for.
Thanks, but database_handler.py is a file, not an app.
I know, you’d need to reload the apps that use database_handler.py.
I don’t know if there is any other option. I myself just restart AppDaemon after developing something new.
So there is no automated way? Seems strange, we can’t be the only ones using multiple source files?
For the development phase I put the database object in my app.py so that all changes are picked up immediately. That works fine for now.
How do you access the database_handler.py functions do you import it as a module or are you doing it with the get_app service call?
I am importing it as a module.
Not tested it myself, but have you tried adding it to the global_modules section in the apps.yaml file? Looks like it should work according to the docs here https://appdaemon.readthedocs.io/en/latest/APPGUIDE.html?highlight=global%20modules#global-module-dependencies
That works, thanks! It would be nice to have this at an app level though since I might have a different database_handler in another app.
Thanks for the help!
That would also work. Just name the files db_handler_for_app_1 and db_handler_for_app_2 etc, and put them all in the global_modules section.
