2017-03-28 07:09:51.800094 INFO AppDaemon Version 1.5.2 starting
2017-03-28 07:09:51.803960 WARNING Unable to connect to Home Assistant, retrying in 5 seconds
2017-03-28 07:09:56.811073 WARNING Unable to connect to Home Assistant, retrying in 5 seconds
I’ve also tried changing the app_dir = /conf/apps in the appdaemon config to app_dir = /home/adam/Docker/homeassistant/config/apps with the same result. Any idea what I’ve mucked up?
I gave it a go, but the same result unfortunately. I removed my front-end password as well to make sure that wasn’t blocking anything.
I probably should ask more questions, but is the ha_key = in the appdaemon.cfg supposed to have your front end password in there? (if not what is the ha_key?)
You shouldn’t need to do anything special to connect to HA via docker, but do specify the ha_key if you have a password on your home assistant instance.
Definitely don’t use localhost, use the IP of the machine HA is running on and remove the trailing “/”. IF that doesn’t work we can look at some additional debug info.
2017-03-30 17:15:40.562142 WARNING Unable to connect to Home Assistant, retrying in 5 seconds
2017-03-30 17:15:45.590381 WARNING Unable to connect to Home Assistant, retrying in 5 seconds
2017-03-30 17:15:50.618638 WARNING Unable to connect to Home Assistant, retrying in 5 seconds
2017-03-30 17:15:55.647313 WARNING Unable to connect to Home Assistant, retrying in 5 seconds
2017-03-30 17:16:00.676223 WARNING Unable to connect to Home Assistant, retrying in 5 seconds
@aimc I have done it as you suggested but I have the same result as before:
root@DSM01:~# docker run -v /etc/localtime:/etc/localtime:ro -v /volume1/docker/homeassistant/config/conf:/conf -v /volume1/docker/homeassistant/config/certs:/certs --restart always --net=host --name appdaemon mezz64/appdaemon
2017-03-30 17:40:44.450834 INFO AppDaemon Version 1.5.2 starting
2017-03-30 17:40:44.469180 WARNING Unable to connect to Home Assistant, retrying in 5 seconds
2017-03-30 17:40:49.488777 WARNING Unable to connect to Home Assistant, retrying in 5 seconds
Usage: docker run [OPTIONS] IMAGE [COMMAND] [ARG…]
Run a command in a new container
-a, --attach= Attach to STDIN, STDOUT or STDERR
–add-host= Add a custom host-to-IP mapping (host:ip)
–blkio-weight Block IO (relative weight), between 10 and 1000
–blkio-weight-device= Block IO weight (relative device weight)
–cpu-shares CPU shares (relative weight)
–cap-add= Add Linux capabilities
–cap-drop= Drop Linux capabilities
–cgroup-parent Optional parent cgroup for the container
–cidfile Write the container ID to the file
–cpu-period Limit CPU CFS (Completely Fair Scheduler) period
–cpu-quota Limit CPU CFS (Completely Fair Scheduler) quota
–cpuset-cpus CPUs in which to allow execution (0-3, 0,1)
–cpuset-mems MEMs in which to allow execution (0-3, 0,1)
-d, --detach Run container in background and print container ID
–detach-keys Override the key sequence for detaching a container
–device= Add a host device to the container
–device-read-bps= Limit read rate (bytes per second) from a device
–device-read-iops= Limit read rate (IO per second) from a device
–device-write-bps= Limit write rate (bytes per second) to a device
–device-write-iops= Limit write rate (IO per second) to a device
–disable-content-trust=true Skip image verification
–dns= Set custom DNS servers
–dns-opt= Set DNS options
–dns-search= Set custom DNS search domains
-e, --env= Set environment variables
–entrypoint Overwrite the default ENTRYPOINT of the image
–env-file= Read in a file of environment variables
–expose= Expose a port or a range of ports
–group-add= Add additional groups to join
-h, --hostname Container host name
–help Print usage
-i, --interactive Keep STDIN open even if not attached
–ip Container IPv4 address (e.g. 172.30.100.104)
–ip6 Container IPv6 address (e.g. 2001:db8::33)
–ipc IPC namespace to use
–isolation Container isolation technology
–kernel-memory Kernel memory limit
-l, --label= Set meta data on a container
–label-file= Read in a line delimited file of labels
–link= Add link to another container
–log-driver Logging driver for container
–log-opt= Log driver options
-m, --memory Memory limit
–mac-address Container MAC address (e.g. 92:d0:c6:0a:29:33)
–memory-reservation Memory soft limit
–memory-swap Swap limit equal to memory plus swap: ‘-1’ to enable unlimited swap
–memory-swappiness=-1 Tune container memory swappiness (0 to 100)
–name Assign a name to the container
–net=default Connect a container to a network
–net-alias= Add network-scoped alias for the container
–oom-kill-disable Disable OOM Killer
–oom-score-adj Tune host’s OOM preferences (-1000 to 1000)
-P, --publish-all Publish all exposed ports to random ports
-p, --publish= Publish a container’s port(s) to the host
–pid PID namespace to use
–pids-limit Tune container pids limit (set -1 for unlimited)
–privileged Give extended privileges to this container
–read-only Mount the container’s root filesystem as read only
–restart=no Restart policy to apply when a container exits
–rm Automatically remove the container when it exits
–security-opt= Security Options
–shm-size Size of /dev/shm, default value is 64MB
–sig-proxy=true Proxy received signals to the process
–stop-signal=SIGTERM Signal to stop a container, SIGTERM by default
-t, --tty Allocate a pseudo-TTY
–tmpfs= Mount a tmpfs directory
-u, --user Username or UID (format: <name|uid>[:<group|gid>])
–ulimit= Ulimit options
–userns User namespace to use
–uts UTS namespace to use
-v, --volume= Bind mount a volume
–volume-driver Optional volume driver for the container
–volumes-from= Mount volumes from the specified container(s)
-w, --workdir Working directory inside the container
I’m running HA on docker, can some please give me a quick guide on how to get appdaemon running on Synology NAS, I’m trying to piece this all together from different posts etc running HA on docker seems like a real pain as every time I do something the normal guides I need to follow don’t work and then I have to spend hours trying to put it all together. I need appdaemon so I can get HADashboard running.
