Is it possible to transition the lights to off. Ive tried self.turn_off(id, 10) but this errors with TypeError: turn_off() takes 2 positional arguments but 3 were given
Cheers
Zak
Cheers
Zak
You can send anything the trun_off
service accepts but you would use keywords not just parameters, e.g.
self.turn_off("light.hall", transition = 10)
Thats how I thought it would work as well. I get the following error when I do that
TypeError: turn_off() got an unexpected keyword argument âtransitionâ
self.turn_off(entry, transition = 10)
PS: If I havent said this already, thanks for all your hard work on AppDaemon, it really makes HA for me
Looking at the def for turn_off I dont think it supports the transition param
def turn_off(self, entity_id):
self._check_entity(entity_id)
self.call_service(âhomeassistant/turn_offâ, entity_id = entity_id)
Ok, Iâll take a look at that - in the meantime you can use call_sevice() and that should accept the transition parameter.
call service works perfectly. cheers
