Hi everybody!
Recently I gave a user some feedback who was looking to convert their YAML Automation file to the app-based Python structure of AppDaemon. It dawned on me that a lot of users who are using AppDaemon are seeking the extra flexibility that Python can afford to offer, but may not necessarily be familiar with how to write Python in the first place! Some may have a CS background, while others may not. This post is part of a tutorial series of sorts wherein I tackle a problem and show both a simple and complex way to write an AppDaemon app! The simple version will be ready-to-use right out of the box. The complex version will also run “out of the box”, but you’ll likely want to tweak it to work specifically with your own setup! I will go over more advanced concepts and style guide mentions here.
##Tutorials
Tracker-Notifier - monitor devices’
onstate, and receive a notification after a user-specified length of time - Errorlog Notifications - have a persistent notification appear on the dash any time AppDaemon errors out
- Utility Functions - create general purpose functions that other apps can refer to in order to simplify your code
In the easy version, I will try to break the solution down in simple terms so that someone who knows absolutely nothing about Python can understand them. The more complex example will also have a brief description explaining general logic, but will be targeted towards those of you who have a better grasp of the fundamentals.
I hope you enjoy!
#Tutorial #3 - Utility Functions
This tutorial is going to be a bit shorter than usual, as we’re talking more about the concepts of code re-use and sandbox we have to play in is a lot bigger than our previous discussions. The sky is the limit here to be honest! Utility functions will be more geared towards your own setup and what you find you’re doing over and over again, rather than writing a single, functional automation.
— simple —
Before I get into the simple app, I want to first talk about how integral the idea of “reusing well-written code” is to Python, and programming in general. Wouldn’t it be great to write a function that does one thing perfectly, and then re-use that in all your other apps? You’re certainly already doing this, take the following example…
from datetime import timedelta
def ten_minutes_from_now():
Return datetime.datetime object +10 minutes from current internal
AppDaemon clock
return self.datetime() + timedelta(minutes=10)
You should be able to easily tell from the description in red what the app is doing. self.datetime() is @aimc’s helper function that gives you the current time as dictated by AppDaemon. timedelta is a function from the datetime library that expresses “the difference between two date, time, or datetime instances to microsecond resolution.” Both of these functions are code that someone else has written, that we are reusing and now extending to be even more useful to us! Oftentimes when you write a general purpose function like this, it’s helpful to write what we call a docstring or documentation strings. It’s usually a very short descriptor of what’s going on in this function wrapped in triple-quotes (""").
This idea of code re-use is actually one of the main ideas behind AppDaemon. Here we give an example of having written one app that takes various arguments sensor and light, where if motion is detected on sensor, then light needs to turn on. This app is reused three different times, with its parameters filled in for three different sensors: one upstairs, one downstairs, and one in the garage. This way, if you need to change some general logic for motion sensing, you only need to change it in one place.
Let’s going to take a slightly different application on the above approach and instead of developing 1 app that can be used multiple ways, we’ll create a set of utlity functions that can then be used in many of your others apps! We’ll then get the utilities app in the initialization of each of our dependent apps. But enough talking, let’s get coding!
import appdaemon.appapi as appapi
from datetime import datetime, timedelta
# App to localize frequently used functions
# Args: (set these in appdaemon.cfg)
# n/a
# EXAMPLE appdaemon.cfg entry below...
# ... and of how to make utils initialize before other apps
# get the chance to
# # Apps
# [utils]
# module = utils
# class = utils
# [hello_world]
# module = hello_world
# class = HelloWorld
# dependencies = utils
# class HelloWorld(appapi.AppDaemon):
# def initialize(self):
# self.utils = self.get_app('utils')
# self.log('Tomorrow is {}'.format(self.utils.tomorrow())
class utils(appapi.AppDaemon):
pass
def ten_minutes_from_now(self):
AppDaemon clock
def tomorrow(self):
Return datetime.date object +1 day from current internal AppDaemon
clock
return self.date() + timedelta(days=1)
def soon(self, seconds=5):
Return datetime.datetime object some number of seconds from current
internal AppDaemon clock.
Keyword arguments:
seconds -- seconds in the future (default 5)
return self.datetime() + timedelta(seconds=second)
def all_on_lights(self):
Return list of entity_ids for all lights that are currently on
all_lights = self.get_state('light')
all_on_lights = []
for light in all_lights:
state = self.get_state(light)
if state == 'on':
all_on_lights.append(light)
return all_on_lights
def get_max_brightness(self):
Return the maximum brightness value of all lights that are currently on
max_brightness = []
brightness = self.get_state(light, attribute='brightness')
if brightness is not None:
max_brightness.append(brightness)
return max(max_brightness)
def bound_to_255(self, number):
Convert percentage-bound rightness to something that is usable for
HomeAssistant
return round(int(float(number)) * 255 / 100)
def bound_to_100(self, number):
Convert HomeAssistant-usable brightness level to something that is
human readable
return round(int(float(number)) / 255 * 100)
A lot of these are very simple, but allow you to understand how centralizing code in single app can help keep your other apps cleaner. There are various timers in here like soon() and tomorrow() that can help you standardize logic. There are also some functions in here that help you when working with light objects within HomeAssistant. These can be useful when you want to do automation based lighting.
In the app that wants to use your utility functions, you’ll want to get the app during the initalize section so we can access those functions elsewhere.
self.say_tomorrow()
def say_tomorrow():
Hopefully this give you the tools you need in order to start writing your own general purpose logic! If you’ve already got some of these type of functions, I encourage you to share with others in this thread!
#####*You can read up more about code re-use and docstrings conventions at their respective links below.
10 tips on writing reusable code - this article might go over your head a bit, but it’s useful information for all programming languages about writing good code that is intended to be re-used. Take the time to read it, and possibly come back to it as you find yourself getting more comfortable in Python.
__docstring__ - supplies classes for manipulating dates and times in both simple and complex ways.
— complex —
I’ll share with you a couple of functions I use (including some of the above in simple). There is a TON of flexbility when we’re talking about utilities and it really will depend on what you find you’re lacking from the general API.
import json
# n/a
# get the chance to
# # Apps
# [utils]
# module = utils
# class = utils
# [hello_world]
# read into memory data from a configuration file
# this data can be accessed in other apps via "self.get_app('utils').users"
with open('/some/path/to/users.json', 'r') as j:
self.users = json.load(j)
def soon(self, seconds=None, minutes=None, hours=None):
Return datetime.datetime object for some time in the future from
current internal AppDaemon clock.
Keyword arguments:
hours -- hours in the fturue (default None)
minutes -- minutes in the future (default None)
if not seconds:
seconds = 5
if not minutes:
minutes = 0
if not hours:
hours = 0
return self.datetime() + timedelta(seconds=seconds,
minutes=minutes,
hours=hours)
def run_every_weekday(self, callback, start, **kwargs):
Execute a callback at the same time every day of traditional work week.
If today is a work day and the time has already passed, the function
will not be invoked until the following work day at the specified time.
Keyword arguments:
callback -- Function to be invoked when the requested state change
occurs. It must conform to the standard Scheduler Callback
format documented at https://goo.gl/EBtPDx.
start -- A Python time object that specifies when the callback will
occur. If the time specified is in the past, the callback will
occur the next day at the specified time.
**kwargs -- Arbitary keyword parameters to be provided to the callback
function when it is invoked.
WEEKDAYS = ['Monday', 'Tuesday', 'Wednesday', 'Thursday', 'Friday']
handle = []
upcoming_weekdays = []
today = self.date()
todays_event = datetime.combine(today, start)
if todays_event > self.datetime():
if today.strftime('%A') in WEEKDAYS:
upcoming_weekdays.append(today)
for day_number in range(1, 8):
day = today + timedelta(days=day_number)
if day.strftime('%A') in WEEKDAYS:
if len(upcoming_weekdays) < 5:
upcoming_weekdays.append(day)
for day in upcoming_weekdays:
event = datetime.combine(day, start)
handle.append(self.run_every(callback, event, 604800, **kwargs))
return handle
def run_every_weekend_day(self, callback, start, **kwargs):
Execute a callback at the same time every day outside of the
traditional work week. If today is a weekend day and the time has
already passed, the function will not be invoked until the following
weekend day at the specified time.
Keyword arguments:
WEEKEND_DAYS = ['Saturday', 'Sunday']
handle = []
upcoming_weekend_days = []
today = self.date()
if today.strftime('%A') in WEEKEND_DAYS:
upcoming_weekend_days.append(today)
if day.strftime('%A') in WEEKEND_DAYS:
if len(upcoming_weekend_days) < 2:
upcoming_weekend_days.append(day)
for day in upcoming_weekend_days:
return handle
def cancel_multiday_timer(self, handle):
Cancel a previously created weekday or weekend timer
for thing in handle:
try:
for timer in thing:
self.cancel_timer(timer)
except TypeError:
self.cancel_timer(thing)
Aside from a more flexible soon() timer, I’ve also included two timers I’ve found useful for running functions during weekdays and weekends. These are special timers that return a list of handlers, so you’ll need to use cancel_multiday_timer() in order to shut them off.
You’ll also notice that in my initalize section, I assign a variable to users. This variable can be accessed throughout other apps much like below.
self.say_hello_to_users()
def say_hello_to_users():
for user in self.utils.users:
self.notify_user('Hello {}!'.format(user)
Shout out to @aimc for developing this awesome platform we can use to write our complex automations in, and @yawor for helping to clean up and standardize the codebase. What we’re doing here would not be possible without these two, so thank you greatly.
I’ve gone back and forth on what medium to use, including various blogging platforms as well as YouTube. I might experiment with solving a problem “live” and thinking my way through the problem out loud as well.
Feedback is important! This series will only be as successful as you all make it to be! Let me know your thoughts and what you all would like to see, and I’ll consider all my options.
Happy Automating!
- SN
I personally would prefer to write up my own function that go and learn how to format my contraints! It certainly can be useful though, to anyone who wants to see another way of doing it,
