Aephir
December 22, 2023, 10:57pm
1
Any idea why this (see below) has been showing up a lot in my logs?
If I understand this correctly, it’s saying that config
is None
? In which case, would AppDAemon even work? (All my apps work as expected).
Warning that keeps popping up:
2023-12-22 23:25:15.933174 WARNING AppDaemon: Traceback (most recent call last):
File "/usr/lib/python3.11/site-packages/appdaemon/app_management.py", line 578, in read_config_file
return utils.read_config_file(file)
File "/usr/lib/python3.11/site-packages/appdaemon/utils.py", line 586, in read_config_file
return read_yaml_config(path)
File "/usr/lib/python3.11/site-packages/appdaemon/utils.py", line 724, in read_yaml_config
if "secrets" in config:
TypeError: argument of type 'NoneType' is not iterable
proggie
December 28, 2023, 2:28am
2
Take out sensitive parts of your config file and share it. Seems like it might have something to do with using the “secrets” keyword.
Aephir
December 28, 2023, 4:02pm
3
You mean just the appdaemon.yaml
? It’s pretty minimal:
secrets: /homeassistant/secrets.yaml
appdaemon:
latitude: REDACTED
longitude: REDACTED
elevation: REDACTED
time_zone: REDACTED
plugins:
HASS:
type: hass
http:
url: http://127.0.0.1:5050
admin:
api:
hadashboard:
Changed /config/secrets.yaml
to /homeassistant/secrets.yaml
when addon configs moved to the addon_configs
mount.
I’m not really sure which app this is coming from, I have a bunch of app config files split between “types” of things. But I just made a test:
test:
module: test
class: Test
grocy_api_key: !secret grocy_api_key
and if I try logging self.args['grocy_api_key']
from test.py
, I get the correct value from my secrets.yaml
file.
EDIT: I noticed that when I added the test
app, it looked fine. When I commented the config for the app in test.yaml
, this appeared in the logs:
everything logged at that second below
2023-12-28 17:08:26.552702 INFO AppDaemon: Reading config
2023-12-28 17:08:26.612097 WARNING AppDaemon: ------------------------------------------------------------
2023-12-28 17:08:26.612482 WARNING AppDaemon: Unexpected error loading config file: /config/apps/globals/globals.yaml
2023-12-28 17:08:26.612682 WARNING AppDaemon: ------------------------------------------------------------
2023-12-28 17:08:26.613539 WARNING AppDaemon: Traceback (most recent call last):
2023-12-28 17:08:26.613787 WARNING AppDaemon: ------------------------------------------------------------
2023-12-28 17:08:26.617029 WARNING AppDaemon: File '/config/apps/globals/globals.yaml' invalid structure - ignoring
2023-12-28 17:08:26.744541 WARNING AppDaemon: global_modules directive has been deprecated and will be removed in a future release
2023-12-28 17:08:26.749099 WARNING AppDaemon: ------------------------------------------------------------
2023-12-28 17:08:26.749759 WARNING AppDaemon: Unexpected error loading config file: /config/apps/test/test.yaml
2023-12-28 17:08:26.751034 WARNING AppDaemon: ------------------------------------------------------------
2023-12-28 17:08:26.752187 WARNING AppDaemon: Traceback (most recent call last):
2023-12-28 17:08:26.752438 WARNING AppDaemon: ------------------------------------------------------------
2023-12-28 17:08:26.757032 WARNING AppDaemon: File '/config/apps/test/test.yaml' invalid structure - ignoring
2023-12-28 17:08:26.763350 INFO AppDaemon: /config/apps/test/test.yaml added or modified
2023-12-28 17:08:26.823541 INFO AppDaemon: App 'test' deleted
2023-12-28 17:08:26.828439 INFO AppDaemon: Found 61 active apps
2023-12-28 17:08:26.828826 INFO AppDaemon: Found 0 inactive apps
2023-12-28 17:08:26.829435 INFO AppDaemon: Found 0 global libraries
Aephir
January 25, 2024, 10:33am
4
An update, in case this helps.
It seems to me like I get the warning about secrets
whenever there is an app with it’s yaml config commented out, and that config contains a reference to secret
(e.g., the test.yaml
in the logs in previous post).
Does that explain this and/or is that expected? I thought it would just ignore apps with yaml commented out?
Yeah, commented YAML is not looked at so this doesn’t really make any sense.
