AppDaemon will not authorize to MQTT
Running HAOS 25.12.3, installed on Raspberry Pi 5
I’ve installed the addon AppDaemon, but it will not connect to the MQTT broker.
I’ve installed the core-mosquito MQTT broker addon using default configuration settings.
I’ve tried various settings of “Ignore Broker Certificate Validation” with no effect.
I can not change “Broker Certificate Validation” to auto as suggested somewhere.
MQTT Log: 2025-12-18 08:44:16: Client appdaemon_mqtt_client disconnected, not authorised.
AppDaemon Log:
2025-12-18 08:44:58.510137 CRITICAL MQTT: Could not Complete Connection to Broker, please Ensure Broker at URL core-mosquitto:1883 is correct and broker is not down and restart Appdaemon
2025-12-18 08:44:59.503238 CRITICAL MQTT: Could not complete MQTT Plugin initialization, trying again in 5 seconds
2025-12-18 08:45:04.507606 CRITICAL MQTT: Could not complete MQTT Plugin initialization, for Connection was refused due to Not Authorised
2025-12-18 08:45:04.508015 CRITICAL MQTT: MQTT Client Disconnected Abruptly. Will attempt reconnection
2025-12-18 08:45:04.513228 CRITICAL MQTT: Could not complete MQTT Plugin initialization, trying again in 5 seconds
appdaemon.yaml
appdaemon:
time_zone: America/Chicago
latitude: 28.7
longitude: -96.9
elevation: 30
plugins:
HASS:
type: hass
token: !env_var SUPERVISOR_TOKEN
MQTT:
type: mqtt
namespace: mqtt # We will need that same value in the apps.yaml configuration
client_host: core-mosquitto # The IP address or hostname of the MQTT broker
client_port: 1883 # The port of the MQTT broker, generally 1883
verbose: True
http:
url: http://0.0.0.0:5050
admin:
api:
hadashboard:
log:
Can anyone tell me what I’m missing?
Thanks.
