Hi All,
I am attempting to run a python script that craws a website for my smart oil guage. The script works without issue on my local computer but will not run under AppDaemon. Is the below something that AppDaemon can support?
Thank you.
import appdaemon.plugins.hass.hassapi as hass
class oil(hass.Hass):
def initialize(self):
self.listen_event(self.check_oil, "check_oil")
def check_oil(self, event_name, data, kwargs):
self.log("Checking Oil Level")
from selenium import webdriver
import paho.mqtt.publish as publish
from pyvirtualdisplay import Display
display = Display(visible=0, size=(1440, 900))
display.start()
browser = webdriver.Chrome('chrome')
browser.set_window_size(1440, 900)
browser.get("https://app.smartoilgauge.com/app.php")
browser.find_element_by_id("inputUsername").send_keys("redacted")
browser.find_element_by_id("inputPassword").send_keys("redacted")
browser.find_element_by_css_selector("button.btn").click()
browser.implicitly_wait(3)
current_level = browser.find_element_by_xpath('//*[@id="tankFillDiv"]/div[3]').get_attribute("innerHTML")
current_level_value = current_level.split(" ")
browser.quit()
self.log(current_level_value[0])
print(current_level_value[0])
publish.single("oilgauge/tanklevel", current_level_value[0], hostname="192.168.1.100", port=1883,
auth={'username': "redacted", 'password': "redacted"})
display.stop()
Error
2021-01-30 20:23:41.815393 WARNING oil: ------------------------------------------------------------
2021-01-30 20:23:41.814699 WARNING oil: Traceback (most recent call last):
File "/usr/lib/python3.8/site-packages/selenium/webdriver/common/service.py", line 72, in start
self.process = subprocess.Popen(cmd, env=self.env,
File "/usr/lib/python3.8/subprocess.py", line 854, in __init__
self._execute_child(args, executable, preexec_fn, close_fds,
File "/usr/lib/python3.8/subprocess.py", line 1702, in _execute_child
raise child_exception_type(errno_num, err_msg, err_filename)
FileNotFoundError: [Errno 2] No such file or directory: 'chrome'
File "/usr/lib/python3.8/site-packages/appdaemon/threading.py", line 933, in worker
funcref(args["event"], data, self.AD.events.sanitize_event_kwargs(app, args["kwargs"]))
File "/config/appdaemon/apps/oil.py", line 19, in check_oil
File "/usr/lib/python3.8/site-packages/selenium/webdriver/chrome/webdriver.py", line 73, in __init__
self.service.start()
File "/usr/lib/python3.8/site-packages/selenium/webdriver/common/service.py", line 81, in start
raise WebDriverException(
selenium.common.exceptions.WebDriverException: Message: 'chrome' executable needs to be in PATH. Please see https://sites.google.com/a/chromium.org/chromedriver/home
2021-01-30 20:23:41.811232 WARNING oil: ------------------------------------------------------------
2021-01-30 20:23:41.810510 WARNING oil: Worker Ags: {'id': 'b1c649204eba47758d84af589d91b3b1', 'name': 'oil', 'objectid': '57d590300b0646cfaa9510e37aa3e1f1', 'type': 'event', 'event': 'check_oil', 'function': >, 'data': {}, 'pin_app': True, 'pin_thread': 0, 'kwargs': {'__thread_id': 'thread-0'}}
2021-01-30 20:23:41.809167 WARNING oil: Unexpected error in worker for App oil:
2021-01-30 20:23:41.807836 WARNING oil: ------------------------------------------------------------
