Appdaemon.yaml not connected to HA
Hi
I have an https hassio configuration. I’m trying to connect HADashboard to it. I think it’s a certificate verification issue or something like that. Can anyone see anything wrong with my appdaemon.yAML
22
Im getting this error
try adding:
commtype: SSE
the error still occurs
Im also using duck dns will that affect anything
If it helps it doesn’t even work without certificate for Hassio
try running it with -D DEBUG so we can see what the error is.
ok thanks for the help
Did you mention in another post that the duck dns url should be used
Also where do I type -D DEBUG when using hassio
If you are using SSL on home assistant yu have to use the full DNS address or you will get an SSL error - that’s the way that SSL works.
I don;t know - I don;t use hass.io - maybe someone else can help …
is the api_key, api_ssl_certificate for ssl needed
