Appdeamon add-on high CPU usage
I run the appdeamon add-on on my haos based installation. I have not used it to run anything so far. I also keep my installation up to date in terms of versions etc.
Recently I noticed the add-on is using 30-40% CPU, which can impact the performance of home assistant. A restart of the add-on did not fix this.
I attach a screenshot.
Is there anything that could need to be added to the default configuration? (I do not recall ever changing it)
Did you try a full restart of the system?
Not just home assistant but the whole system.
Yes, the system has taken a very long time after restart to become accessible, which I assume is related to the add-on cpu usage
What hardware do you have?
Can you disable the AddOn and also disable start on boot and reboot.
If that is fast, appdaemon is the winner.
Disabling appdaemon did it. Now total cpu usage is 5%, not even usually spiking above 30%.
I have a thin pc with 32G SSD, 8G memory.
➜ ~ ha info
arch: amd64
channel: stable
docker: 28.3.3
features:
  • reboot
  • shutdown
  • services
  • network
  • hostname
  • timedate
  • os_agent
  • haos
  • resolved
  • journal
  • disk
  • mount
    hassos: “16.2”
    homeassistant: 2025.9.2
    hostname: homeassistant
    logging: info
    machine: generic-x86-64
    machine_id: c0844c2ef3da4f9d99c24f318a5bf032
    operating_system: Home Assistant OS 16.2
    state: running
    supervisor: 2025.09.0
    supported: true
    supported_arch:
  • amd64
  • i386
    timezone: Europe/London
➜ ~ ha host info
agent_version: 1.7.2
apparmor_version: 3.1.7
boot_timestamp: 1757982171913901
broadcast_llmnr: true
broadcast_mdns: true
chassis: embedded
cpe: cpe:2.3:o:home-assistant:haos:16.2::production::::generic-x86-64:*
deployment: production
disk_free: 5.9
disk_life_time: null
disk_total: 28.6
disk_used: 21.5
dt_synchronized: true
dt_utc: “2025-09-16T13:13:40.099704+00:00”
features:
  • reboot
  • shutdown
  • services
  • network
  • hostname
  • timedate
  • os_agent
  • haos
  • resolved
  • journal
  • disk
  • mount
    kernel: 6.12.43-haos
    llmnr_hostname: homeassistant
    startup_time: 1.597696
    use_ntp: true
    virtualization: “”
