AppDeamon/HADashboard suddenly stopped working
Hi All,
For some reason my HADashboard stopped working. I don’t really know when exactly As I have been building dashboards for rooms awaiting delivery of some cheap chinese tablets for the rooms. As I wanted to build the dashboards for the rooms of my children I couldn’t reach the HADashboard webserver. It seems as of the webserver does not respond although a portscan whows the webserver identification.
I tried removing the addon and removing the appdaemon folder. This has the same result (did not change anything in the initial config). I also tried to create a diag log from AppDaemon but that stays empty.
I have absolutely no idea how to troubleshoot this further… Can someone please provide me some guidance?
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] 00-banner.sh: executing...
 Hass.io Add-on: AppDaemon
 Python Apps and HADashboard using AppDaemon 3.x for Home Assistant
 Add-on version: 4.1.0
 You are running the latest version of this add-on.
 System: HassOS 2.12  (armv7 / raspberrypi3)
 Home Assistant version: 0.101.2
 Supervisor version: 192
 Please, share the above information when looking for help
 or support in, e.g., GitHub, forums or the Discord chat.
[cont-init.d] 00-banner.sh: exited 0.
[cont-init.d] 01-log-level.sh: executing...
[cont-init.d] 01-log-level.sh: exited 0.
[cont-init.d] appdaemon.sh: executing...
[09:31:34] INFO: Updating Hass.io API token in AppDaemon with the current one...
[cont-init.d] appdaemon.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
[09:31:35] INFO: Starting AppDaemon...
2019-11-06 09:31:38.508736 INFO AppDaemon Version 3.0.5 starting
2019-11-06 09:31:38.509457 INFO Configuration read from: /config/appdaemon/appdaemon.yaml
2019-11-06 09:31:38.515417 INFO AppDaemon: Starting Apps
2019-11-06 09:31:38.529113 INFO AppDaemon: Loading Plugin HASS using class HassPlugin from module hassplugin
2019-11-06 09:31:40.638193 INFO AppDaemon: HASS: HASS Plugin Initializing
2019-11-06 09:31:40.639463 INFO AppDaemon: HASS: HASS Plugin initialization complete
2019-11-06 09:31:40.640739 INFO Starting Dashboards
2019-11-06 09:31:40.674379 INFO API is disabled
2019-11-06 09:31:40.693134 INFO AppDaemon: HASS: Connected to Home Assistant 0.101.2
2019-11-06 09:31:40.957430 INFO AppDaemon: Got initial state from namespace default
2019-11-06 09:31:44.185841 INFO AppDaemon: Reading config
2019-11-06 09:31:44.194627 INFO AppDaemon: /config/appdaemon/apps/apps.yaml added or modified
2019-11-06 09:31:44.195191 INFO AppDaemon: /config/appdaemon/apps/apps.yaml added or modified
2019-11-06 09:31:44.195907 INFO AppDaemon: App 'hello_world' added
2019-11-06 09:31:44.196747 INFO AppDaemon: Adding /config/appdaemon/apps to module import path
2019-11-06 09:31:44.198194 INFO AppDaemon: Loading App Module: /config/appdaemon/apps/hello.py
2019-11-06 09:31:44.239256 INFO AppDaemon: Initializing app hello_world using class HelloWorld from module hello
2019-11-06 09:31:44.525590 INFO hello_world: Hello from AppDaemon
2019-11-06 09:31:44.529613 INFO hello_world: You are now ready to run Apps!
2019-11-06 09:31:44.531605 INFO AppDaemon: App initialization complete
