Anyone have any ideas why my Sinilink smart USB’s (flashed with ESPhome) keep becoming unavailable when connected to my HA blue device; and thus killing my zigbee or zwave networks because the hubs are attached to them.
For troubleshooting heres what I did.
Plugged sinilink into my personal PC. Had RSSI of -45 dBm. Let it sit for 6 hours. Had zero issues. See two pictures below.
Moved sinilink and plugged it into my HA blue device on a USB extension WITHOUT anything else connected to it. Had RSSI of -60 dBm. Let it sit overnight, had over 20 occurances of ‘unavailable’. See two pictures below.
I connected my Zwave hub to the sinilink so that my Zwave network was operational which meant the sinilink was allowing pass thru. I disconnected my wifi router completely. While this did cause the device to show as unavailable, it did NOT make the device kill the pass-thru to the hub; I could still command Zwave devices. If I let it sit like this long enough, the pass through would be momentarily killed but it was not because of loss of wifi.
I have tried this test, albeit in shorter duration with all 3 of my sinilink units, with the same results.
What I think my tests have proved:
• It is not a sinilink specific issue, or it would have happened when plugged into my personal PC.
• It is not a zwave/zigbee/wyze hub CAUSING the issue, as the issue also occurs without any hubs being plugged into the sinilink
• It is not a loss of wifi causing the sinilink to disable its pass thru feature. See point 3.
• It is not the ESPHome yaml or else it should happen when plugged into my personal PC.
• It is not a signal issue. Yes it is stronger when connected to my personal PC, but a google shows -65dBm is still perfectly acceptable.
To me it seems to be something specific happening when the sinilink and my HA blue device are paired. Anyone have any thoughts?
