Hello everyone, I use my Homepod in Home Assistant to use NodeRed to play TTS and sounds for certain events (when and for what exactly would be beyond the scope now :D) If I haven’t been in the dashboard for a few days, my Homepod is very often switched off (see picture). Then of course my programming no longer works and I have to switch the Homepod on again in HA, which is pretty annoying… Why is that? Is there anything I can change to make the Homepod stay on permanently, or is there a command in NodeRed that you can insert that turns the Homepod on?
Have you found a solution for this?
I am also interested in a solution. I’ve also switched on that the devices will be set to on after restart of HA but that covers only restart. Does solve that devices turn automatically off which causes that automations do not work. Really annoying
