Hi All,
tried to add the integration of Apple iCloud but I see a error message:
2020-01-16 19:38:55 ERROR (MainThread) [homeassistant.config_entries] Error setting up entry [email protected] for icloud
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 215, in async_setup
hass, self
File "/usr/src/homeassistant/homeassistant/components/icloud/__init__.py", line 158, in async_setup_entry
await hass.async_add_executor_job(account.setup)
File "/usr/src/homeassistant/homeassistant/components/icloud/__init__.py", line 300, in setup
for prs_id, member in user_info["membersInfo"].items():
AttributeError: 'NoneType' object has no attribute 'items'
Is it working fine for you? Just switch from the iCloud yaml to front end and the info aren’t up to date (even after 30mn, the account fetch interval).
iCloud integration worked for me on 104.0 but later it didn’t. I can add the integration successfuly but there are no devices. On 105 now. I get this:
File “/usr/src/homeassistant/homeassistant/config_entries.py”, line 215, in async_setup
hass, self
File “/usr/src/homeassistant/homeassistant/components/icloud/init.py”, line 124, in async_setup_entry
File “/usr/local/lib/python3.7/concurrent/futures/thread.py”, line 57, in run
File “/usr/src/homeassistant/homeassistant/components/icloud/account.py”, line 124, in setup
self.update_devices()
File “/usr/src/homeassistant/homeassistant/components/icloud/account.py”, line 168, in update_devices
self._fetch_interval = self._determine_interval()
File “/usr/src/homeassistant/homeassistant/components/icloud/account.py”, line 239, in _determine_interval
int(min(intervals.items(), key=operator.itemgetter(1))[1]),
ValueError: min() arg is an empty sequence
