Apple TV app won't launch in automation but will launch manually
I have this automation which works as expected. The Moonlight app launches on the Apple TV at the end. (Ignore the silly conditions that’s legacy from when I had a more complex setup for this, need to change it)
alias: 'Entertainment: PC Streaming Start'
description: Wake Gaming PC & Living Room PC when PC Stream activity started
  - entity_id: remote.harmony_hub
    platform: state
condition:
  - condition: or
    conditions:
      - condition: template
        value_template: >-
          {{ is_state_attr(trigger.to_state.entity_id, 'current_activity', 'PC
          Stream') }}
        value_template: >-
          {{ is_state_attr(trigger.to_state.entity_id, 'activity_starting', 'PC
          Stream') }}
  - service: switch.turn_on
    data: {}
    entity_id: switch.gaming_pc
  - delay:
      hours: 0
      minutes: 0
      seconds: 15
      milliseconds: 0
  - service: media_player.select_source
      source: Moonlight
      entity_id: media_player.living_room
mode: single
However the TV Clock app does not launch at the end of this one and I cannot figure out why. The trace shows the automation runs and if I add other actions to it they run, but the TV Clock app won’t launch. If I run the automation manually (or call the service the same way under Developer Tools) it works so I know the action is correct. I also tried quoting “TV Clock” because of the space but it just removes it and as said it still runs when triggered manually even with the space.
alias: 'Entertainment: Audio (Music) Start'
description: ''
    platform: state
    attribute: current_activity
    to: Apple TV Audio
condition: []
  - delay:
      hours: 0
      minutes: 0
      seconds: 15
      milliseconds: 0
      source: TV Clock
mode: single
Trace
Executed: February 19, 2022, 10:26:44 AM
Result:
params:
  domain: media_player
  service: select_source
  service_data:
    source: TV Clock
    entity_id:
      - media_player.living_room
    entity_id:
running_script: false
limit: 10
Suggestions?
