Long time reader, first time post …
At night, we fall asleep watching TV on Apple TV with the Channels App (using a SiliconDust HD Homerun Prime). Since Apple TV does not have a sleep timer, or Channels, it will continue to play content on Channels, or other Apps (i.e. Netflix). There is a CURL command that I can schedule and will stop channels playback, but will not apply if watching another App.
I would like to use HomeAssistant to schedule a MENU command to be sent to Apple TV at 01:00. This will stop playback, eventually Apple TV and TV (via HDMI CEC) will enter power save and turn off. I know the concept works because I am currently using a BroadLink IR Control Hub to do this, sending the Menu command at 01:00, but I just want to reduce clutter.
I’ve successfully added the Apple TV to my configuration.yaml
# Apple_TV
apple_tv:
- host: 10.0.1.27
login_id: XXXX
start_off: true
credentials: XXXX
I’m trying to call the following in automations.yaml, it triggers correctly, but the command is not taking place on Apple TV. What am I doing wrong?
- id: ATV_Master_Bedroom_Automation
alias: "Turn Off Master Bedroom TV @ 01:00AM"
- platform: time
at: '01:00:00'
- service: remote.send_command
entity_id: media_player.master_bedroom
command:
- top_menu
