Apple TV - Cannot reinstall Apple TV integration
Hi All,
Appreciate any help here.
I installed the Apple TV inregration and everything went fine.
I then uninstalled the integration (new to HA and was playing around) and when I tried to reinstall Apple TV I couldnt.
At the very beginning Apple TV was auto detected but not anymore. So I seach for Apple TV in integrations and add integration. I am asked for the IP address and I add the IP address in Apple TV settings. I am then asked for a pin number, which is displayed and I enter it. Then i get the error
  • Aborted. The configuration for this device is incomplete. Please try adding it again.
For other reasons, I have completely factory reset the Apple TV and I have started a HA again from the beginning but the same problem persists.
Any help would be most appreciated.
I am getting the same error as well. My apple tvs were not longer providing status to HA, so I decided to remove them and reinstall the integration. When I attempt to add them back, I get PIN code, enter and get them error message.
Just found you need to install the beta if you are running TV OS 15
