Apple TV - Find Source Name - Node Red
Hi.
I have setup the following integration to connect to my Apple TV. Via Node red i am able to get Apple TV to open NetFlix using the media source. Thats a pretty easy one to open.
However how do i find out what the correct source name is for other apps like Amazon Prime etc
inject node > current state (apple tv) > debug node (output msg.data)
Under attributes should be the source. Change the source on the TV manually then run the above flow to see the current source
