I installed the Apple TV integration a few days ago for my new 4K 2nd generation version. The integration seems to work ok when the ATV is running but if its in standby it throws errors, oscillating between off and standby or losing connection with the device completely for a time.
I have read various threads about it, made sure enabled for everyone on the network is correctly set for example but nothing seems to correct this odd behaviour. All this shows up in the log minutes after re-starting HASS:-
2023-07-20 10:11:41.655 ERROR (MainThread) [pyatv.protocols.airplay] Failed to set up remote control channel
File “/usr/local/lib/python3.11/site-packages/pyatv/protocols/airplay/init.py”, line 289, in _connect_rc
await session.connect()
File “/usr/local/lib/python3.11/site-packages/pyatv/protocols/airplay/ap2_session.py”, line 63, in connect
self.connection = await http_connect(self._address, self._control_port)
File “/usr/local/lib/python3.11/site-packages/pyatv/support/http.py”, line 631, in http_connect
_, connection = await loop.create_connection(HttpConnection, address, port)
File “/usr/local/lib/python3.11/asyncio/base_events.py”, line 1085, in create_connection
raise exceptions[0]
File “/usr/local/lib/python3.11/asyncio/base_events.py”, line 1069, in create_connection
sock = await self._connect_sock(
File “/usr/local/lib/python3.11/asyncio/base_events.py”, line 973, in _connect_sock
await self.sock_connect(sock, address)
File “/usr/local/lib/python3.11/asyncio/selector_events.py”, line 634, in sock_connect
return await fut
File “/usr/local/lib/python3.11/asyncio/selector_events.py”, line 674, in _sock_connect_cb
raise OSError(err, f’Connect call failed {address}’)
OSError: [Errno 113] Connect call failed (‘192.168.1.147’, 7000)
2023-07-20 10:11:44.727 ERROR (MainThread) [homeassistant.components.apple_tv] Failed to connect
File “/usr/src/homeassistant/homeassistant/components/apple_tv/init.py”, line 222, in connect_once
await self._connect(conf, raise_missing_credentials)
File “/usr/src/homeassistant/homeassistant/components/apple_tv/init.py”, line 324, in _connect
self.atv = await connect(conf, self.hass.loop, session=session)
File “/usr/local/lib/python3.11/site-packages/pyatv/init.py”, line 135, in connect
await atv.connect()
File “/usr/local/lib/python3.11/site-packages/pyatv/core/facade.py”, line 681, in connect
if await setup_data.connect():
File “/usr/local/lib/python3.11/site-packages/pyatv/protocols/companion/init.py”, line 573, in _connect
await api.connect()
File “/usr/local/lib/python3.11/site-packages/pyatv/protocols/companion/api.py”, line 143, in connect
await self._protocol.start()
File “/usr/local/lib/python3.11/site-packages/pyatv/protocols/companion/protocol.py”, line 101, in start
await self.connection.connect()
File “/usr/local/lib/python3.11/site-packages/pyatv/protocols/companion/connection.py”, line 80, in connect
await self.loop.create_connection(lambda: self, self.host, self.port)
raise exceptions[0]
return await fut
OSError: [Errno 113] Connect call failed (‘192.168.1.147’, 49153)
2023-07-20 10:11:44.732 WARNING (MainThread) [homeassistant.config_entries] Config entry ‘Main Bedroom’ for apple_tv integration not ready yet: Not found at 192.168.1.147, waiting for discovery; Retrying in background
2023-07-20 10:11:47.799 ERROR (MainThread) [pyatv.protocols.airplay] Failed to set up remote control channel
raise exceptions[0]
return await fut
2023-07-20 10:11:50.872 ERROR (MainThread) [homeassistant.components.apple_tv] Failed to connect
await atv.connect()
await api.connect()
raise exceptions[0]
return await fut
2023-07-20 10:12:04.311 ERROR (MainThread) [pyatv.protocols.airplay] Failed to set up remote control channel
raise exceptions[0]
return await fut
2023-07-20 10:12:07.384 ERROR (MainThread) [homeassistant.components.apple_tv] Failed to connect
await atv.connect()
await api.connect()
raise exceptions[0]
return await fut
2023-07-20 10:12:30.680 ERROR (MainThread) [pyatv.protocols.airplay] Failed to set up remote control channel
raise exceptions[0]
return await fut
2023-07-20 10:12:33.751 ERROR (MainThread) [homeassistant.components.apple_tv] Failed to connect
await atv.connect()
await api.connect()
raise exceptions[0]
return await fut
Any ideas what is causing this because as it is I cannot really use the integration reliably?
