Thanks for the reply. I am not using a firewall or VLAN. The IP address is not the one of Ha. Here is the detailed error.
Logger: homeassistant.components.script.patrick_home
Source: helpers/script.py:485
Integration: Skript (documentation, issues)
First occurred: 15:22:53 (3 occurrences)
Last logged: 20:01:08
patrick_home: Error executing script. Unexpected error for call_service at pos 1: HTTPConnectionPool(host='192.168.5.78', port=8123): Max retries exceeded with url: /api/tts_proxy/11eed11b5910a1c7857e065d619963865c385ec4_de-ch_e09b5a0968_cloud.audiooutput.mp3 (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x7f5db3c440>: Failed to establish a new connection: [Errno 113] Host is unreachable'))
patrick_home: Error executing script. Unexpected error for call_service at pos 1: HTTPConnectionPool(host='192.168.5.78', port=8123): Max retries exceeded with url: /api/tts_proxy/11eed11b5910a1c7857e065d619963865c385ec4_de-ch_e09b5a0968_cloud.audiooutput.mp3 (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x7f3f7a1070>: Failed to establish a new connection: [Errno 113] Host is unreachable'))
patrick_home: Error executing script. Unexpected error for call_service at pos 1: HTTPConnectionPool(host='192.168.5.78', port=8123): Max retries exceeded with url: /api/tts_proxy/11eed11b5910a1c7857e065d619963865c385ec4_de-ch_e09b5a0968_cloud.audiooutput.mp3 (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x7efb9be5a0>: Failed to establish a new connection: [Errno 113] Host is unreachable'))
File "/usr/local/lib/python3.12/site-packages/pyatv/protocols/raop/audio_source.py", line 597, in open
stream_generator = await loop.run_in_executor(
File "/usr/local/lib/python3.12/concurrent/futures/thread.py", line 58, in run
File "/usr/local/lib/python3.12/site-packages/miniaudio.py", line 1268, in stream_any
raise DecodeError("failed to init decoder", result)
miniaudio.DecodeError: ('failed to init decoder', -17)
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 485, in _async_step
await getattr(self, handler)()
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 723, in _async_call_service_step
response_data = await self._async_run_long_action(
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 685, in _async_run_long_action
return long_task.result()
File "/usr/src/homeassistant/homeassistant/core.py", line 2279, in async_call
response_data = await coro
File "/usr/src/homeassistant/homeassistant/core.py", line 2316, in _execute_service
return await target(service_call)
File "/usr/src/homeassistant/homeassistant/components/tts/legacy.py", line 148, in async_say_handle
await hass.services.async_call(
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 892, in entity_service_call
single_response = await _handle_entity_call(
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 962, in _handle_entity_call
result = await task
File "/usr/src/homeassistant/homeassistant/components/apple_tv/media_player.py", line 304, in async_play_media
await self.atv.stream.stream_file(media_id)
File "/usr/local/lib/python3.12/site-packages/pyatv/core/facade.py", line 371, in stream_file
await self.relay("stream_file")(
File "/usr/local/lib/python3.12/site-packages/pyatv/protocols/raop/__init__.py", line 360, in stream_file
audio_file = await open_source(
File "/usr/local/lib/python3.12/site-packages/pyatv/protocols/raop/audio_source.py", line 729, in open_source
return await InternetSource.open(source, sample_rate, channels, sample_size)
File "/usr/local/lib/python3.12/site-packages/pyatv/protocols/raop/audio_source.py", line 610, in open
raise ProtocolError(source.error_message) from ex
pyatv.exceptions.ProtocolError: HTTPConnectionPool(host='192.168.5.78', port=8123): Max retries exceeded with url: /api/tts_proxy/11eed11b5910a1c7857e065d619963865c385ec4_de-ch_e09b5a0968_cloud.audiooutput.mp3 (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x7f5db3c440>: Failed to establish a new connection: [Errno 113] Host is unreachable'))
