Apple TV Integration
Hello the Community,
Since migrating to HA version 2023.7 (before I was in 2023.4) the AppleTV Beta integration doesn’t seem to work anymore (and neither does the embedded version in the Apple integration).
When trying to add the integration, I get the error :
Config flow could not be loaded: 500 Internal Server Error Server got itself in trouble
I’ve tried to correct this by deleting config/.storage/smartthings, but I don’t have the file.
Have you encountered this problem? I can’t find a solution on the various forums.
Thank you for your help.
System Information
version core-2023.7.3
installation_type Home Assistant OS
dev false
hassio true
docker true
user root
virtualenv false
python_version 3.11.4
os_name Linux
os_version 6.1.21-v8
arch aarch64
timezone Europe/Paris
config_dir /config
Home Assistant Community Store
GitHub API ok
GitHub Content ok
GitHub Web ok
GitHub API Calls Remaining 5000
Installed Version 1.32.1
Stage running
Available Repositories 1275
Downloaded Repositories 26
Home Assistant Cloud
logged_in false
can_reach_cert_server ok
can_reach_cloud_auth ok
can_reach_cloud ok
Home Assistant Supervisor
host_os Home Assistant OS 10.3
update_channel stable
supervisor_version supervisor-2023.07.1
agent_version 1.5.1
docker_version 23.0.6
disk_total 457.7 GB
disk_used 24.9 GB
healthy true
supported true
board rpi4-64
supervisor_api ok
version_api ok
installed_addons File editor (5.6.0), Samba share (10.0.2), Duck DNS (1.15.0), Grafana (9.0.2), InfluxDB (4.7.0), Node-RED (14.4.2), Mosquitto broker (6.2.1), Advanced SSH & Web Terminal (15.0.5), Z-Wave JS (0.1.84), Studio Code Server (5.9.0), Zigbee2MQTT (1.32.1-1), Samba Backup (5.2.0)
Dashboards
dashboards 5
resources 21
views 41
mode storage
Recorder
oldest_recorder_run July 23, 2023 at 2:58 PM
current_recorder_run July 24, 2023 at 5:53 PM
estimated_db_size 2144.28 MiB
database_engine sqlite
database_version 3.41.2
Remove the beta Integration, it hasn’t been updated in line forever. The built in version is up to date.
Thank you @postlund .
I just removed it from HACS and I encountered the same error when I tried to add Apple TV integration (thru Apple official)
Please check the log file for any errors that might help.
Actually, it works great but it’s mandatory to reboot HA first.
Thank you very much for your help @postlund
