I’m hoping someone has an easy answer to this before I start digging in to source code. I’m trying to add an Apple TV to Home Assistant directly via the static IP address assigned by my router. However, HA always tells me that “no devices were found on the network.”
I have checked the following:
- I can ping the ATV IP from HA
- Bonjour is enabled and the ATV is discoverable on the network by other devices
- I can also control the ATV from my iPhone on the same network using the Remote app
FWIW, I previously had an ATV setup with HA a couple years ago. This is a new (latest gen) ATV with HA v2021.09
