it is possible to downgrade to ios 14?
No idea, Iâve never run any beta version. But I assume it should be possible, at least until final version is out.
So once 15 is released we will all lose the ability to use the ATV integration? Or is this a beta thing?
Looks like that is the case, yes. Unless something changes in a late beta.
Autodiscovery and manually adding my AppleTV 4K stopped working a week ago.
core-2021.7.4
supervisor-2021.06.8
The ATV is running IOS14.4.
Any ideas of how to make it work again?
Upgrade to 2021.8.0 as there is a fix for the discovery issue.
Thank you! I was not aware it was a known bug. I appreciate the fast response. It works now!
Good morning;
Iâm probably going to ask a question that somebody already asked;
- is it possible to keep the remote control always on A? or remove the switch.
Without it, no order can be executed.
I use the HDMI CEC between my LG OLED TV > My Onkyo Amp > APPLE TV.
It works great with the physical remote control but Iâd like to do the same with HA.
Do you have a solution?
Thank you
I use the LG integration side-by-side with the ATV integration to achieve what I want. For instance, we donât have a mute command in the ATV integration, but you can just send the command to the TV which should be transmitted to your amp (mine does so to a Yamaha sound bar). All the mute button on the new ATV remote is doing anyway is sending a CEC command.
switches:
lg_mute:
friendly_name: lg mute
value_template: >
{{ state_attr('media_player.lg_tv', 'is_volume_muted') == true }}
turn_on:
service: media_player.volume_mute
entity_id: media_player.lg_tv
is_volume_muted: "true"
turn_off:
is_volume_muted: "false"
icon_template: >-
{% if (state_attr('media_player.lg_tv', 'is_volume_muted') == true) %}
mdi:volume-mute
{% else %}
mdi:volume-mute
{% endif %}
there are some news with ios 15?
See this thread:
Hi @postlund
First: Really nice integration and good to see you keep updating.
Question: Iâm trying to use an automation to turn_on the AppleTV after my Samsung TV turns on. The automation works but for some reason it wonât turn_on the AppleTV. Is there another option to turn the AppleTV on?
Hmm, turning on should work. It works a lot better if Companion is paired. Can you list and launch apps?
Hi @postlund,
Not really sure what you mean with âCompanion is pairedâ (canât find it in the docs what the âcompanionâ is?)
Iâm using the following automation but this wonât âturn_onâ the AppleTV.
alias: AppleTV turned on by Samsung TV
description: When Samsung TV turns on, turn on AppleTV
- platform: device
device_id: caf472e22a1117ab93bb54ef7b26fef0
domain: media_player
entity_id: media_player.samsung_q90_series_55
type: turned_on
condition: []
- type: turn_on
device_id:
entity_id: remote.appletv
domain: remote
- service: notify.mobile_app_iphone
message: AppleTV turned on by Samsung TV
title: AppleTV turned on
mode: single
Some extra information: When viewing the Apple TV history itâs displaying âstandbyâ. So the device is already turned on (?) but wonât be recognised by the TV (HDMI) unless I use the âscreenâ button on the Apple TV remote.
